Power supply problems.
(04-25-2018, 01:34 AM)larsen8989 Wrote: I use an at to DC in to power my board. now the other day I unplugged my power unit everything was switched off before I did and such. when i plugged it back in my amprage was significantly lower my VSB wire is usually 3A at 5V now it's reading .25A at 5V and the 12V wires are all reading 1A roughly and I was wondering if any one has encountered this problem before.
Sent from my VS995 using Tapatalk
at to DC in?
Do you mean a ATX computer power supply? Amperage being low isn't a problem as that is simply the amount of work being done, but you do have a problem if the voltage (pressure) is low, as it either means the power supply is overloaded (unlikely since you say the amperage is low) or the power supply is faulty (also unlikely if the voltage is low).
If you meant 0.25V on the 5v line, and 1.0V on the 12v line, then it sounds like you need to load up the power supply or instruct it to actually turn on, as ATX power supplies are not meant for light duty loads, or to 'just turn on'.
Power supply problems. - by larsen8989 - 04-25-2018, 01:34 AM
RE: Power supply problems. - by pfeerick - 04-26-2018, 06:22 PM
Power supply problems. - by larsen8989 - 04-26-2018, 07:58 PM
RE: Power supply problems. - by pfeerick - 04-26-2018, 11:59 PM
Power supply problems. - by larsen8989 - 04-27-2018, 12:32 AM
RE: Power supply problems. - by tllim - 05-03-2018, 09:01 PM
  Which Power Supply Unit for Pine64 A64 DB V1.1 2GB REV B (year 2016)? databaseprogrammer 1 4,154 07-03-2021, 01:29 AM
Lightbulb Alternate Power DC-IN on the Euler Bus also with PI filter for batt operation MarkHaysHarris777 13 30,414 12-19-2020, 09:53 PM
Last Post: evilpete
  Once Again: Power Supply problems I guess (Pine A64+ locking up) marcelser 0 4,147 06-04-2018, 03:11 PM
Last Post: marcelser
  solar power on a Pine64 tablet Little_Johnny 11 21,045 03-20-2018, 12:01 AM
Last Post: pfeerick
  Power up HDDs c4tich 3 8,206 03-18-2017, 09:18 AM
Last Post: Luke
  Provide power in via Pi-2 header BenCranston 22 38,451 03-08-2017, 10:38 PM
Last Post: pfeerick
  any danger from using 2 power sources at same time? dkryder 3 8,786 01-20-2017, 10:45 PM
Last Post: MarkHaysHarris777
Lightbulb A Tale of Two Power Supplies - why good is good and better is best MarkHaysHarris777 9 22,673 01-07-2017, 11:59 PM
Last Post: aegrotatio
  First cable for Euler Bus power done! AVL2016 24 41,762 10-05-2016, 06:43 AM
Last Post: Ghost
  Fuse in the AC power line? cr2016 3 8,460 10-02-2016, 04:35 AM
Last Post: pfeerick
