eMMC card on adapter
(01-30-2018, 12:17 PM)xalius Wrote: Hi, there is no standard for eMMC connectors, since those get usually soldered directly on boards. So you usually have to get one that matches the modules you buy... the Pine64 modules use the same connector as the ODROID modules though... the one you bought is used to solder a eMMC on the backside...
Oh crap. That means I'll have to wait for another delivery from the other side of the globe before I can start playing with my new toy. Stupid!
Anyone knows if Pine64 or Hardkernel has the fastest deliveries to Europe?
eMMC card on adapter - by Malmgren - 01-30-2018, 12:14 PM
RE: eMMC card on adapter - by xalius - 01-30-2018, 12:17 PM
RE: eMMC card on adapter - by Malmgren - 01-30-2018, 01:09 PM
RE: eMMC card on adapter - by tllim - 01-30-2018, 04:05 PM
RE: eMMC card on adapter - by Malmgren - 01-31-2018, 12:19 AM
RE: eMMC card on adapter - by Malmgren - 02-07-2018, 04:09 AM
RE: eMMC card on adapter - by xalius - 02-07-2018, 05:10 AM
RE: eMMC card on adapter - by Malmgren - 02-07-2018, 09:01 AM
RE: eMMC card on adapter - by Malmgren - 03-20-2018, 11:14 AM
  eMMC empty? bluedemon382 0 770 07-19-2023, 06:29 AM
Last Post: bluedemon382
  USB adapter to eMMC module not recognized danril 0 1,324 11-25-2022, 04:16 AM
Last Post: danril
  AC Adapter Which One? Pine64 A64 DB V1.1 2GB REV B (Year 2016) databaseprogrammer 2 3,460 06-17-2021, 05:35 AM
Last Post: kqlnut
  How to boot from SD card on pinebook pro linux123 3 6,089 12-02-2020, 10:29 AM
Last Post: linux123
  micro sd card won't insert Samuel Venable 2 4,477 09-01-2020, 12:15 AM
Last Post: Samuel Venable
  SD Card boot - trying out OS Baconomics 1 4,383 06-19-2020, 06:58 AM
  How to flash Focal Gnome to EMMC cyphr3x 0 2,134 06-05-2020, 02:06 PM
Last Post: cyphr3x
  How to boot from the SD card and install to eMMC? ravanh 2 6,472 03-18-2020, 09:42 AM
  recommended micro sd card ? mronhb 91 213,257 03-03-2020, 11:34 PM
Last Post: siyatalerja
  USB C hub and Ethernet adapter jaysistar 3 6,245 01-20-2020, 04:07 PM
Last Post: belfastraven
