USB C hub and Ethernet adapter
I have a Pinebook Pro, and I'd like to connect it to a hard wired network.
I have 2 different USB-C hubs that I could use, and here's a link to them on Amazon:
1. https://www.amazon.com/gp/product/B07TVSLDND/
2. https://www.amazon.com/gp/product/B07QJXP3DV/
I've tried both, and while it seems that USB ports on these devices work, the ethernet ports don't seem to work or show in `ip a` or `ifconfig`.
How do I get the ethernet port to work or 1 or both of these devices?
(01-20-2020, 08:23 AM)jaysistar Wrote: Hello,
What distribution are you using?  and, have you tried plugging in the device "upside down",  that is oposite the cable orientation you are currently using.  A number of people have noted that some of the devices  work only if they are plugged in in a particular  orientation,  although that is not SUPPOSED to matter with a usbc cable.    I have one such device..  https://www.amazon.com/gp/product/B07Z7H3GJK  I am  using Manjaro.
What distribution are you using?  and, have you tried plugging in the device "upside down",  that is oposite the cable orientation you are currently using.  A number of people have noted that some of the devices  work only if they are plugged in in a particular  orientation,  although that is not SUPPOSED to matter with a usbc cable.    I have one such device..  [/url][url=https://www.amazon.com/gp/product/B07Z7H3GJK]https://www.amazon.com/gp/product/B07Z7H3GJK  I am  using Manjaro.
I'm not sure what the distribution is called. It's Debian derived, and it was what was pre-installed on the Pinebook Pro.
Plugging the hub in upside down seems to do the same thing as plugging it in as I had it.
A tail of `/var/log/syslog`seems to give messages regarding the xhci-hcd USB driver when I plug it in. It also says something about `device not accepting address 4, error -71`.
I really don't need the USB, VGA, or HDMI on this hub; I just want the ethernet port and the charge by USB-C capabilities. The charging works, the USB seems to work. The ethernet doesn't.
If you are sure that these have working ethernet by tring them on another computer, I would try another distribution. Just use an sd card version of perhaps Manjaro,  (not one that installs to emmc,  just one that installs and runs on SD) --or any distribution that uses a newer kernel.   It is possible that various drivers have changed.  I have used the hub I mentioned,  as well as another  old anker usb 3 ethernet adapter and both have worked.
If my device is installed on the PBP but not connected to the etherneti I will see etho with ip a as down,  and it will show as UP when it is connected.
I suggest using a distribution with a new kernel in case you are seeing some kind of driver or other software issue.
  USB adapter to eMMC module not recognized danril 0 3,001 11-25-2022, 04:16 AM
Last Post: danril
  AC Adapter Which One? Pine64 A64 DB V1.1 2GB REV B (Year 2016) databaseprogrammer 2 6,524 06-17-2021, 05:35 AM
Last Post: kqlnut
  RockPro64 ethernet issues: DMA engine initialization failed slowcamp 1 5,677 04-26-2021, 06:03 AM
Last Post: slowcamp
  ethernet lan speed problem android fulltone 0 3,811 04-23-2018, 01:47 AM
Last Post: fulltone
  Here Is another mini-how-to to install Raspbian:DESKTOP/ETHERNET/HDMI speedro86 4 12,117 04-15-2018, 07:37 AM
Last Post: bunkerWHz
  eMMC card on adapter Malmgren 8 18,005 03-20-2018, 11:14 AM
Last Post: Malmgren
  HDMI-VGA adapter. Blank screen. trumad 10 26,492 03-05-2017, 03:17 AM
Last Post: pfeerick
  5.25 V _ ... 2A Power USB Adapter Guest2000 4 11,316 02-12-2017, 09:34 PM
