How to boot from the SD card and install to eMMC?
Hi, wanting to try another OS (the new Manjaro) I downloaded the emmc installler image and flashed it to a 16GB SanDisk microSD with the PINE64 INSTALLER utility.
However, my Pinebook Pro refuses to boot from the SD card as long as the internal eMMC drive is swithced on. After switching it off with the little toggle under the hood, I can boot from SD card but then... How to install to the internal drive?
Can anyone point me to some clear instructions either on the wiki or these forums? For a noob it's completely confusing...
Thanks! Smile
(03-16-2020, 07:01 AM)ravanh Wrote: Hi, wanting to try another OS (the new Manjaro) I downloaded the emmc installler image and flashed it to a 16GB SanDisk microSD with the PINE64I INSTALLER utility.
Thanks! Smile
I found a post saying to update the PC with the Mrfixit script first. I did this, but I still cannot boot from the SD card that I loaded Manjaro to. I'm looking for a solution as well.
(03-18-2020, 09:34 AM)pb1051 Wrote: I found a post saying to update the PC with the Mrfixit script first. I did this, but I still cannot boot from the SD card that I loaded Manjaro to. I'm looking for a solution as well.
Which Manjaro image are you trying to boot? Do you recall if the script updated your uboot (it would've been towards the tail end of the scripts output, last thing I think.)
If not, you can try updating it manually using the files from the repo.
https://github.com/mrfixit2001/updates_r...filesystem
Download the idbloader, trust, and uboot .imgs to you PBP, navigate to them in a terminal and run these commands:
dd if=idbloader.img of=/dev/youremmc bs=32k seek=1 conv=fsync
dd if=uboot.img of=/dev/youremmc bs=64k seek=128 conv=fsync
dd if=trust.img of=youremmc bs=64k seek=192 conv=fsync
  Star64: All listed distros don't boot tantamount 0 502 05-08-2026, 08:56 AM
Last Post: tantamount
Sad PINETAB-V doesn't boot. FEC 1 3,199 08-23-2025, 02:58 PM
Last Post: Woazboat
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 3 6,005 12-10-2024, 07:23 PM
Last Post: Dendrocalamus64
  [Star64] Help needed in understanding Yocto and U-boot build process InterestedinFOSS 0 3,013 04-23-2024, 10:58 AM
Last Post: InterestedinFOSS
  linux-headers and quartz64-post-install package conflicts Berzerkleyfan 2 4,311 12-01-2023, 05:17 AM
Last Post: Berzerkleyfan
  eMMC empty? bluedemon382 0 2,312 07-19-2023, 06:29 AM
Last Post: bluedemon382
  Boot Ox64 after SPI Flash IC replacement kotnitro 1 3,573 05-26-2023, 02:19 AM
Last Post: kotnitro
  Star64 first boot (and success) bortzmeyer 1 4,435 05-24-2023, 02:45 AM
Last Post: draintroup
  USB adapter to eMMC module not recognized danril 0 2,995 11-25-2022, 04:16 AM
Last Post: danril
  PBP Debian 11 GRUB install error zlth 2 4,536 11-18-2022, 07:42 AM
Last Post: zlth
