Help debug my pine64A+ ubuntu/plex hangs
(09-21-2017, 10:55 AM)XaRz Wrote: Ok solved the cron
no need of root in the crontab line if I just edit with sudo crontab -e.
Now what about my syslog? it's a heat problem?
Usually all that is needed is a passive cooling device;  generally a 14mm x 14mm  aluminum heatsink with 3M thermal tape adhesive.   All of my boards are being used as servers of one type or another , and all of them have active cooling;  soft-pwm driven 5v brushless fan on either a PN2222 or 2N2222 transistor;  a 4N35 optical coupler may be used as well.
The lack of passive cooling may or may not have anything to do with the eth drop;  although, throttling can be a networking problem, not necessarily.   Try the heatsink first ( any Raspberry PI heatsink will do ) and see what happens, then decide if you need active cooling also;  if you do, I can help you set that up.
RE: Help debug my pine64A+ ubuntu/plex hangs - by MarkHaysHarris777 - 09-21-2017, 10:09 PM
  Issues with both Deb and Ubuntu germanshep 0 2,539 08-28-2018, 05:47 PM
Last Post: germanshep
  Plex Home Theater? jpenberthy 0 2,399 03-07-2017, 02:15 PM
Last Post: jpenberthy
  Ubuntu 16.04 cannot resolve dns - connection timed out; no servers could be reached marcosti 2 10,113 03-01-2017, 02:46 PM
Last Post: dkryder
Question Ultrawide Display for Ubuntu Mate DE dudeytsang 1 5,036 01-01-2017, 07:26 AM
Last Post: CaptainZalo
  Pine64+Ubuntu+Tvheadend+DVBT Dongle Shai 3 6,418 10-03-2016, 04:23 AM
Last Post: Shai
  Dmesg output Ubuntu Mate S265 1 3,625 10-02-2016, 07:28 AM
Last Post: MarkHaysHarris777
  Overclocking ubuntu mate Mixermic 2 4,994 10-01-2016, 04:36 AM
Last Post: pfeerick
  How to make multicast working on ubuntu and debian brengthdom 3 7,056 09-18-2016, 02:05 PM
Last Post: brengthdom
  Camera support - Ubuntu Xenial 16.04 LTS @lex 3 5,254 08-07-2016, 03:47 AM
Last Post: romansavrulin
  [How-To] Make PINE 64 with Ubuntu Xenial Longsleep build crunch BOINC Tasks moisesmcardona 3 8,131 07-27-2016, 01:16 PM
Last Post: NexusDude
