Boot from SD card / boot options
I have exactly the same symptom/problem as DannyJack, see: https://forum.pine64.org/showthread.php?tid=7507 in the linux section of the forum.
Maybe its caused by an old sd-card? Did you try a new one? That's the next step I'm going to try......
Update: i tried the q40s image for 1080 pinebook and it works!!!!
Boot from SD card / boot options - by lodger - 06-16-2017, 11:56 AM
RE: Boot from SD card / boot options - by xalius - 06-16-2017, 02:54 PM
RE: Boot from SD card / boot options - by lodger - 06-17-2017, 04:45 AM
RE: Boot from SD card / boot options - by Luke - 05-17-2019, 09:05 AM
RE: Boot from SD card / boot options - by giel - 05-23-2019, 06:09 AM
RE: Boot from SD card / boot options - by giel - 05-27-2019, 08:23 AM
RE: Boot from SD card / boot options - by xalius - 11-25-2019, 07:35 AM
  Booting with TOC0 u-boot -- should it work? dreadbit 0 793 11-24-2022, 10:19 AM
Last Post: dreadbit
  Few questions about flashing to a MicroSD card on the Pinebook Pro SanjevR 6 9,961 12-07-2020, 04:02 PM
Last Post: SanjevR
  eMMC boot linux distros for Pinebook. frank-zappa 14 21,153 09-06-2019, 08:39 AM
Last Post: frank-zappa
  Link to 11.6 pinebook mainboard schematics for removing wifi card Shoananas 0 2,018 05-19-2019, 04:46 PM
Last Post: Shoananas
  Is it possible to choose between SD/eMMC boot programmatically? UltraBloxX 2 4,911 01-28-2019, 11:41 AM
Last Post: UltraBloxX
  [SOLVED] Can't boot when SD card inserted jschall 5 7,913 11-17-2018, 11:53 AM
Last Post: jschall
  Boot from MicroSD ramboton 3 5,491 11-16-2018, 06:04 PM
Last Post: Luke
  How to mount new microSD card? jschall 8 8,928 11-12-2018, 11:04 AM
Last Post: jschall
  Move Installation from SD Card to eMMC? soupbowl 4 8,924 11-10-2018, 10:47 AM
Last Post: acruhl
  Dual Boot on eMMC? d97 1 3,638 08-30-2017, 10:04 AM
Last Post: abrmx
