solar power on a Pine64 tablet
(03-19-2018, 03:51 AM)pfeerick Wrote: @Madhuwesly,
And yes, if a battery is present, the AXP803 will act like a UPS... if there is enough current to run or charge, it will run from the VBUS/ACIN, else it will run from the battery. Or, I should say, that is how the pine64 and pinebook, which are basically the same hardware (A64 processor, AXP803 PMIC, etc) operate.
Thanks for the clarification Smile !
Yes, if there is enough current to run or charge, AXP803 will run from the VBUS/ACIN, else it will run from the battery. But, will there be any logic circuitry in AXP803, which can combine(mixing) the supplies(Current) of both VBUS and Battery whenever there is no sufficient/enough current from VBUS(here 6V Solar Panel is connected)?
Thanks & regards,
solar power on a Pine64 tablet - by Little_Johnny - 05-20-2017, 02:48 AM
RE: solar power on a Pine64 tablet - by pfeerick - 05-20-2017, 06:48 PM
RE: solar power on a Pine64 tablet - by pfeerick - 05-20-2017, 09:07 PM
RE: solar power on a Pine64 tablet - by pfeerick - 03-19-2018, 03:51 AM
RE: solar power on a Pine64 tablet - by Madhuwesly - 03-19-2018, 11:35 PM
RE: solar power on a Pine64 tablet - by pfeerick - 03-20-2018, 12:01 AM
  Which Power Supply Unit for Pine64 A64 DB V1.1 2GB REV B (year 2016)? databaseprogrammer 1 3,105 07-03-2021, 01:29 AM
Lightbulb Alternate Power DC-IN on the Euler Bus also with PI filter for batt operation MarkHaysHarris777 13 25,589 12-19-2020, 09:53 PM
Last Post: evilpete
  Once Again: Power Supply problems I guess (Pine A64+ locking up) marcelser 0 3,532 06-04-2018, 03:11 PM
Last Post: marcelser
  Power supply problems. larsen8989 5 9,361 05-03-2018, 09:01 PM
  Power up HDDs c4tich 3 6,362 03-18-2017, 09:18 AM
Last Post: Luke
  Provide power in via Pi-2 header BenCranston 22 29,649 03-08-2017, 10:38 PM
Last Post: pfeerick
  any danger from using 2 power sources at same time? dkryder 3 6,952 01-20-2017, 10:45 PM
Last Post: MarkHaysHarris777
Lightbulb A Tale of Two Power Supplies - why good is good and better is best MarkHaysHarris777 9 18,372 01-07-2017, 11:59 PM
Last Post: aegrotatio
  First cable for Euler Bus power done! AVL2016 24 33,195 10-05-2016, 06:43 AM
Last Post: Ghost
  Fuse in the AC power line? cr2016 3 6,819 10-02-2016, 04:35 AM
Last Post: pfeerick
