solar power on a Pine64 tablet
I am Madhuwesly, working on a Carrier Board based on SOPine A64 SOM module.
Q1:
It is mentioned in AXP803 data-sheet that "AXP803 features an IPS circuit to transparently select power path among DCIN/USB(VBUS)/Li-Battery to system load", What I want to do is in-place of USB(VBUS) supply option I want to provide 6V Solar panel supply directly to the VUSB pins, will there be any issues with this kind of configuration?
Q2:
It is also mentioned that "If the current is still insufficient, charge current will be reduced to zero, and battery is used for one of the power sources", so whenever the current is insufficient from Solar panel, will it consider automatically the battery power source as one of the power source??
Thanks & regards,
solar power on a Pine64 tablet - by Little_Johnny - 05-20-2017, 02:48 AM
RE: solar power on a Pine64 tablet - by pfeerick - 05-20-2017, 06:48 PM
RE: solar power on a Pine64 tablet - by pfeerick - 05-20-2017, 09:07 PM
RE: solar power on a Pine64 tablet - by Madhuwesly - 03-19-2018, 12:38 AM
RE: solar power on a Pine64 tablet - by pfeerick - 03-19-2018, 03:51 AM
RE: solar power on a Pine64 tablet - by pfeerick - 03-20-2018, 12:01 AM
  Which Power Supply Unit for Pine64 A64 DB V1.1 2GB REV B (year 2016)? databaseprogrammer 1 3,134 07-03-2021, 01:29 AM
Lightbulb Alternate Power DC-IN on the Euler Bus also with PI filter for batt operation MarkHaysHarris777 13 25,700 12-19-2020, 09:53 PM
Last Post: evilpete
  Once Again: Power Supply problems I guess (Pine A64+ locking up) marcelser 0 3,546 06-04-2018, 03:11 PM
Last Post: marcelser
  Power supply problems. larsen8989 5 9,427 05-03-2018, 09:01 PM
  Power up HDDs c4tich 3 6,412 03-18-2017, 09:18 AM
Last Post: Luke
  Provide power in via Pi-2 header BenCranston 22 29,852 03-08-2017, 10:38 PM
Last Post: pfeerick
  any danger from using 2 power sources at same time? dkryder 3 6,996 01-20-2017, 10:45 PM
Last Post: MarkHaysHarris777
Lightbulb A Tale of Two Power Supplies - why good is good and better is best MarkHaysHarris777 9 18,482 01-07-2017, 11:59 PM
Last Post: aegrotatio
  First cable for Euler Bus power done! AVL2016 24 33,454 10-05-2016, 06:43 AM
Last Post: Ghost
  Fuse in the AC power line? cr2016 3 6,865 10-02-2016, 04:35 AM
Last Post: pfeerick
