USB cable to power device
(02-26-2016, 03:49 PM)Ron Piggott Wrote: Would you look at this one for me, there are restrictions on the first one I found that I can't buy several for my coming Pine cluster.
80cm USB 2.0 A Male to Micro 5 Pin Male Plug Adapter Short Power Data Cable Cord
(I know I have to have power for each board)
Any microUSB cable should be fine, including that one.
Since you are planning to use on a cluster, you may select a long cable that is flexible.
When do you expect to receive your Pine64s? If it is more than one month, you can buy
from Aliexpress. Select a seller that has good reputation and there is lots of positive feedback.
Aliexpress is good because sellers are fighting to build reputation.
If a cable has a defect, you can ask for a new one to be sent.
USB cable to power device - by Ron Piggott - 02-26-2016, 01:03 PM
RE: USB cable to power device - by Ghost - 02-26-2016, 01:19 PM
RE: USB cable to power device - by tatopillo - 05-02-2016, 05:08 PM
RE: USB cable to power device - by Tarjei85 - 02-26-2016, 01:22 PM
RE: USB cable to power device - by Ron Piggott - 02-26-2016, 02:03 PM
RE: USB cable to power device - by Tarjei85 - 02-26-2016, 02:12 PM
RE: USB cable to power device - by taros - 02-26-2016, 02:46 PM
RE: USB cable to power device - by Ron Piggott - 02-26-2016, 03:49 PM
RE: USB cable to power device - by Tarjei85 - 02-26-2016, 04:13 PM
RE: USB cable to power device - by taros - 02-26-2016, 04:36 PM
RE: USB cable to power device - by Ghost - 02-26-2016, 05:32 PM
RE: USB cable to power device - by Luke - 05-02-2016, 05:44 PM
RE: USB cable to power device - by xmasone - 05-06-2016, 04:29 PM
  Which Power Supply Unit for Pine64 A64 DB V1.1 2GB REV B (year 2016)? databaseprogrammer 1 3,129 07-03-2021, 01:29 AM
Lightbulb Alternate Power DC-IN on the Euler Bus also with PI filter for batt operation MarkHaysHarris777 13 25,687 12-19-2020, 09:53 PM
Last Post: evilpete
  Once Again: Power Supply problems I guess (Pine A64+ locking up) marcelser 0 3,546 06-04-2018, 03:11 PM
Last Post: marcelser
  Power supply problems. larsen8989 5 9,426 05-03-2018, 09:01 PM
  solar power on a Pine64 tablet Little_Johnny 11 15,916 03-20-2018, 12:01 AM
Last Post: pfeerick
  Power up HDDs c4tich 3 6,409 03-18-2017, 09:18 AM
Last Post: Luke
  Provide power in via Pi-2 header BenCranston 22 29,800 03-08-2017, 10:38 PM
Last Post: pfeerick
  any danger from using 2 power sources at same time? dkryder 3 6,992 01-20-2017, 10:45 PM
Last Post: MarkHaysHarris777
Lightbulb A Tale of Two Power Supplies - why good is good and better is best MarkHaysHarris777 9 18,465 01-07-2017, 11:59 PM
Last Post: aegrotatio
  First cable for Euler Bus power done! AVL2016 24 33,436 10-05-2016, 06:43 AM
Last Post: Ghost
