Corrupted SD card?
I know Gparted takes issue with overlapping partitions present in some Android builds, not sure if that is a factor here or not.
Also, far as I know, unless you have a battery attached, trying to power on the Pine via the power button won't work. Again, not sure if this is true of all OS's, but it is certainly true of some. I can't boot Android 7.0 by simply pressing the power button, only by removing and reinserting the power cable, or powering off and back on at the wall socket. If I try to power on via the power button, the red led light will come on for a few seconds and then go off again, as you described.
Corrupted SD card? - by Passiday - 10-22-2016, 06:31 AM
RE: Corrupted SD card? - by Ghost - 10-22-2016, 06:53 AM
RE: Corrupted SD card? - by Passiday - 10-22-2016, 07:19 AM
RE: Corrupted SD card? - by Ghost - 10-22-2016, 11:31 AM
RE: Corrupted SD card? - by Passiday - 10-22-2016, 01:52 PM
RE: Corrupted SD card? - by Ghost - 10-22-2016, 05:47 PM
RE: Corrupted SD card? - by Pepe - 10-22-2016, 03:13 PM
  Issues with SD Card and Running Android Twistedx 0 3,588 02-26-2019, 11:58 AM
Last Post: Twistedx
  Corrupt SD Card? CaptainCWA 13 17,189 06-04-2017, 08:01 PM
Last Post: pfeerick
  Editing SD card simplexdan 2 4,071 02-25-2017, 12:09 PM
Last Post: simplexdan
  android image & sd card size problems tomarneson 11 17,990 01-24-2017, 05:31 AM
Last Post: ayufan
  Creating bootable SD card on Mac OS X colinj 13 20,650 01-24-2017, 03:03 AM
Last Post: MarkHaysHarris777
  SD card too small Error loungehound 7 12,793 01-21-2017, 05:37 PM
Last Post: Bluphire
  Setting up SD card and installing rooted Android using an ubuntu machine edszr.co 4 6,764 09-22-2016, 03:56 PM
Last Post: edszr.co
  Can't read SD card on Mac/Win after mounting DD Android image Voyager 3 5,605 09-04-2016, 12:05 PM
Last Post: Boring
  Android Marshmallow SDK is corrupted Terra854 1 3,026 08-24-2016, 01:33 PM
Last Post: NGC6691
  Image sizes too big for SD card? montero65 29 43,413 07-28-2016, 03:12 AM
Last Post: gbjensen
