Question regarding Playbox case
(09-13-2016, 05:50 PM)jeffrey_ring Wrote: Hi Mark!  Thank you for your suggestion.  I went ahead and ordered a similar cable to the one you suggested and it just arrived today.  I plugged it in to the microSD slot on the board, placed my microSD into its SD holder and plugged the SD holder into the other end of the cable.  Powered up and it seems to work just fine!  :-)  This should make it easier to swap out OSs.  Thanks again!
You are welcome; I'm glad it worked out ok for you, and others will be glad too, because anyone attempting to use the ABS playbox will run into this same problem.
Question regarding Playbox case - by jeffrey_ring - 09-09-2016, 07:27 PM
RE: Question regarding Playbox case - by MarkHaysHarris777 - 09-13-2016, 07:39 PM
Big Grin Super Mario case [NOW WITH UPDATED STL-FILE (April 27.)] Tarjei85 37 64,778 07-23-2020, 05:31 AM
Last Post: devendraraju
  Made a case for the Pine64 with Audio DAC installed kodachrome 1 3,992 11-12-2019, 04:52 AM
Last Post: xalius
  Playbox with DAC llungster 0 2,750 04-02-2019, 09:02 AM
Last Post: llungster
  playbox case ribbon cable too short pinoosh 7 12,425 02-22-2019, 03:24 AM
Last Post: GaryFunk
  Clear case PIne 64 with VESA100 LIPO , RTC holder, and mini fan holes killor 6 11,635 08-05-2017, 07:15 AM
Last Post: killor
  New Pine 64 Screen Case from C4Labs Dustin_C4Labs 11 19,108 07-18-2017, 10:39 AM
Information Giving the Pine a trunk, a Playbox pedestal tommypine 7 10,236 07-16-2017, 01:51 AM
Last Post: selina3
  A case with active cooling for 1Gb pine64 ishwest 5 10,129 06-28-2017, 04:05 AM
Last Post: ishwest
Rainbow (Cluster) Modified Playbox Enclosure Progress predominant 3 5,501 06-17-2017, 01:29 AM
Last Post: pfeerick
  Lego Case Kiryu 67 89,772 03-30-2017, 11:36 AM
Last Post: Luke
