Power Pine64 via GPIO
(04-13-2016, 03:36 AM)TeaPack Wrote:
(04-02-2016, 10:36 AM)Andrew2 Wrote:
(04-02-2016, 09:57 AM)HeadShot Wrote: So, can anyone tell me the max Vin for this board?
The power requirements are clearly written: 5V/2A. If you want to destroy the board feel free to inject higher voltages (5.1V maybe even 5.2V are fine, especially when powering through Micro USB since voltage drops will occur anyway)
Regarding test points please have a look at the schematic (no idea whether this has been released or not)
Well, PMIC on this board can work with max of 7V and unfortunately, microUSB is connected directly to Eulers pins, so there is danger of destroying other devices connected to microUSB port, when Pine is powered over pins...
complete schematics:
https://drive.google.com/file/d/0B0cEs0l...sp=sharing
PMIC datasheet:
https://github.com/OLIMEX/OLINUXINO/blob...t_V1.0.pdf
Keep in mind that schematic is not valid as it relates to power on the 2Gb model, there were changes and that revised schematic has not been posted.
Just because the PMIC has a tolerance of 7v doesnt mean they designed the board so that anything else sharing its Vcc rail can handle that. Why, I bet there are capacitors on the board rated for 16v.....
Also according to that schematic D+ and D- on microusb are not connected, so, what would you hook to it other than power?
Power Pine64 via GPIO - by dulasu - 01-25-2016, 11:05 PM
RE: Power Pine64 via GPIO - by Opine - 01-25-2016, 11:17 PM
RE: Power Pine64 via GPIO - by 1q84 - 03-14-2016, 10:16 PM
RE: Power Pine64 via GPIO - by tllim - 03-15-2016, 09:22 AM
RE: Power Pine64 via GPIO - by dulasu - 01-26-2016, 01:02 AM
RE: Power Pine64 via GPIO - by Nilocsemliw - 01-26-2016, 11:37 AM
RE: Power Pine64 via GPIO - by Zoidiano0 - 03-15-2016, 05:34 AM
RE: Power Pine64 via GPIO - by HeadShot - 04-01-2016, 09:27 PM
RE: Power Pine64 via GPIO - by Zoidiano0 - 04-01-2016, 09:32 PM
RE: Power Pine64 via GPIO - by Andrew2 - 04-02-2016, 12:18 AM
RE: Power Pine64 via GPIO - by xmasone - 05-06-2016, 04:24 PM
RE: Power Pine64 via GPIO - by HeadShot - 04-02-2016, 09:57 AM
RE: Power Pine64 via GPIO - by Andrew2 - 04-02-2016, 10:36 AM
RE: Power Pine64 via GPIO - by TeaPack - 04-13-2016, 03:36 AM
RE: Power Pine64 via GPIO - by rahlquist - 04-13-2016, 08:22 AM
RE: Power Pine64 via GPIO - by TeaPack - 04-13-2016, 09:43 AM
  Which Power Supply Unit for Pine64 A64 DB V1.1 2GB REV B (year 2016)? databaseprogrammer 1 3,128 07-03-2021, 01:29 AM
Lightbulb Alternate Power DC-IN on the Euler Bus also with PI filter for batt operation MarkHaysHarris777 13 25,670 12-19-2020, 09:53 PM
Last Post: evilpete
  Once Again: Power Supply problems I guess (Pine A64+ locking up) marcelser 0 3,544 06-04-2018, 03:11 PM
Last Post: marcelser
  Power supply problems. larsen8989 5 9,422 05-03-2018, 09:01 PM
  solar power on a Pine64 tablet Little_Johnny 11 15,901 03-20-2018, 12:01 AM
Last Post: pfeerick
  Power up HDDs c4tich 3 6,408 03-18-2017, 09:18 AM
Last Post: Luke
  Provide power in via Pi-2 header BenCranston 22 29,785 03-08-2017, 10:38 PM
Last Post: pfeerick
  any danger from using 2 power sources at same time? dkryder 3 6,989 01-20-2017, 10:45 PM
Last Post: MarkHaysHarris777
Lightbulb A Tale of Two Power Supplies - why good is good and better is best MarkHaysHarris777 9 18,453 01-07-2017, 11:59 PM
Last Post: aegrotatio
  First cable for Euler Bus power done! AVL2016 24 33,423 10-05-2016, 06:43 AM
Last Post: Ghost
