Alternate Power DC-IN on the Euler Bus also with PI filter for batt operation
Addendum:  PI  low_pass  filter:
This little device pictured above has been discussed on the forum (and the irc channel) often enough that it warrants further explanation and an hour of my time this afternoon.  This is called a low-pass or PI filter (PI because of the shape the schematic makes). The device cleans up noisy DC line voltage by 'passing' the DC voltage and blocking the noise (RF signals, dc-dc converter noise, automobile noise, &c).  This little filter can take a 100mv ripple in the DC line voltage and quiet it down to less than 10mv literally. It is a passive circuit, requires no energy (very little), and is relatively easy to build, even by novice EE maker types.
All four capacitors are 6.3v 1000mf caps (taken from an old PC planar board) and the toroid inductor is also a very common PC planar board inductor (in fact, these components were pulled off an old ACER planar this afternoon, and were themselves used there as a low-pass filter!)    ( they live again... isn't resurrection marvelous ! )
This device is particularly handy if your DC power cord is very long, if you live in an area with high electrical noise or radio towers, or if you plan to put your PineA64 in your automobile.
RE: Alternate Power DC-IN on the Euler Bus - by MarkHaysHarris777 - 08-12-2016, 02:36 PM
  Which Power Supply Unit for Pine64 A64 DB V1.1 2GB REV B (year 2016)? databaseprogrammer 1 3,122 07-03-2021, 01:29 AM
  Once Again: Power Supply problems I guess (Pine A64+ locking up) marcelser 0 3,541 06-04-2018, 03:11 PM
Last Post: marcelser
  Power supply problems. larsen8989 5 9,402 05-03-2018, 09:01 PM
  solar power on a Pine64 tablet Little_Johnny 11 15,864 03-20-2018, 12:01 AM
Last Post: pfeerick
  Power up HDDs c4tich 3 6,391 03-18-2017, 09:18 AM
Last Post: Luke
  Provide power in via Pi-2 header BenCranston 22 29,709 03-08-2017, 10:38 PM
Last Post: pfeerick
  any danger from using 2 power sources at same time? dkryder 3 6,978 01-20-2017, 10:45 PM
Last Post: MarkHaysHarris777
Lightbulb A Tale of Two Power Supplies - why good is good and better is best MarkHaysHarris777 9 18,438 01-07-2017, 11:59 PM
Last Post: aegrotatio
  Correct Voltage For Powering From Euler?? thisrestricted 7 11,341 10-18-2016, 06:49 PM
Last Post: veronicasmithen03
  First cable for Euler Bus power done! AVL2016 24 33,330 10-05-2016, 06:43 AM
Last Post: Ghost
