Gentoo Linux test image
I should really get around to make a new image... and whoever uses the test image should see that the latest kernel is used from longsleep's release repo at https://github.com/longsleep/linux-pine64/releases especially since the GbE fix happened after I made the image... also the people from linux-sunxi are making good progress on the A64 mainlining effort and at least for headless mainline kernels should be usable by now...
Re kernel building, you can not boot a mainline kernel with the BSP u-boot... only works for BSP kernels! If you want to boot mainline you have to use upstream ATF, u-boot and spl ...
Gentoo Linux test image - by xalius - 08-04-2016, 01:58 PM
RE: Gentoo Linux test image - by xalius - 08-05-2016, 02:34 AM
RE: Gentoo Linux test image - by xalius - 08-07-2016, 07:47 AM
RE: Gentoo Linux test image - by jkmooney - 08-28-2016, 09:17 AM
RE: Gentoo Linux test image - by Detritus - 09-18-2016, 12:12 PM
RE: Gentoo Linux test image - by tampadave - 09-24-2016, 12:16 AM
RE: Gentoo Linux test image - by jkmooney - 10-01-2016, 06:31 PM
RE: Gentoo Linux test image - by jkmooney - 10-01-2016, 07:36 PM
RE: Gentoo Linux test image - by kevinava - 12-12-2016, 02:01 AM
RE: Gentoo Linux test image - by xalius - 01-07-2017, 07:04 AM
RE: Gentoo Linux test image - by shaggy013 - 01-15-2017, 05:32 AM
RE: Gentoo Linux test image - by xalius - 01-15-2017, 05:48 AM
RE: Gentoo Linux test image - by ivantheviking - 02-28-2017, 11:41 AM
RE: Gentoo Linux test image - by xalius - 02-28-2017, 11:48 AM
RE: Gentoo Linux test image - by ivantheviking - 02-28-2017, 06:30 PM
RE: Gentoo Linux test image - by xalius - 03-24-2017, 06:05 AM
RE: Gentoo Linux test image - by incoherent - 12-09-2017, 01:04 PM
RE: Gentoo Linux test image - by necrose99 - 04-28-2018, 08:41 AM
RE: Gentoo Linux test image - by robopsi - 06-25-2018, 04:47 AM
RE: Gentoo Linux test image - by tllim - 06-26-2018, 12:39 PM
Gentoo Linux test image - by necrose99 - 01-28-2019, 11:05 PM
  NEMS Linux 1.5 Released for A64/A64+, A64-LTS/SOPine, Rock64, RockPro64 (NAGIOS) Baldnerd 4 9,331 03-28-2020, 06:20 PM
Last Post: ty1911
  Howto run Linux with resolution other than 1080p longsleep 28 66,949 06-13-2019, 01:53 AM
Last Post: Nilda
  NEMS Linux for Pine A64 (+) Luke 1 5,148 05-09-2019, 05:42 PM
Last Post: pineadmin
  Pine Board using linux stuck during boot sequence ktaragorn 4 8,310 03-30-2019, 06:48 AM
Last Post: ktaragorn
  Real-time linux kernel Artyom 45 73,300 09-11-2018, 01:08 AM
Last Post: zzwpine
  linux distribution hazerty 3 6,210 04-01-2018, 02:48 PM
Last Post: dkryder
  Linux Web Server OS harcrow 2 5,857 01-30-2018, 10:26 AM
Last Post: Rustproof
  Gentoo for pine64 - longsleep kernel incoherent 0 3,659 12-09-2017, 08:14 AM
Last Post: incoherent
  Found this fully working RASPBIAN Image that boots to desktop speedro86 21 29,142 10-07-2017, 10:06 PM
Last Post: speedro86
  eta linux image?? firosiro 1 4,094 08-03-2017, 10:05 PM
Last Post: pfeerick
