battery power in android
#36
(09-15-2016, 05:10 AM)dcmorley Wrote:
(09-01-2016, 05:32 PM)MarkHaysHarris777 Wrote:
(09-01-2016, 03:55 PM)dcmorley Wrote:
(09-01-2016, 05:03 AM)MarkHaysHarris777 Wrote:
(09-01-2016, 04:36 AM)dcmorley Wrote: I'm going nuts...please HELP.
I finally got my PlayBox. I installed a 10000mha li ion 3.7v 2 wire battery by soldering + & - to the bottom of 1 and 3 pins of the battery connector with the proper polarity and switched the jumper to the Batt position. Assembled it all together and tried to give it a full charge. I'm running the Pine Android LCD image. The battery shows it's charging in Android but the % doesn't increase. I then powered off leaving the 5v usb power supply that came with the board plugged in and the system switched over to charge mode. I left it sit for 16 hrs and when I powered up again Android shows exactly the same % of charge. What's going on???
The PMIC will NOT charge the batter using a two wire system.  The third wire (the center one, yellow on three wire systems) is required so that the charge system can monitor the temperature.
You may 'fool' the PMIC by running a 10K ohm resistor from the center pin(2) to ground, on a two wire system, and then the PMIC will charge the battery.
(hope this helps you)
ThankX Mark, I'll try that. At least I now know.
(09-01-2016, 05:03 AM)MarkHaysHarris777 Wrote: The PMIC will NOT charge the batter using a two wire system.  The third wire (the center one, yellow on three wire systems) is required so that the charge system can monitor the temperature.
Mark, Should I use a thermistor or is it safe to just use a resistor?
A thermistor doesn't buy you anything because its not mounted in the battery package.  You may use a standard half watt 10K ohm resistor.
Mark, I just got back here and saw your reply AFTER I picked up 100 10k Ω 1/4 watt resistor is the 1/4 watt good enough?
Yes, it probably is going to be just fine.  If you want to make sure (I have not measured it) you can measure the current by taking a voltage drop reading across the resistor-- do the math, if voltage times current is 0.250 or less a 1/4 watt resistor will work fine. Its really a pull-down resistor to ground and not much current passes through it I suspect.
battery power in android - by UnixOutlaw - 07-31-2016, 02:54 AM
RE: battery power in android - by xalius - 07-31-2016, 03:36 AM
RE: battery power in android - by UnixOutlaw - 07-31-2016, 05:29 AM
RE: battery power in android - by xalius - 07-31-2016, 05:36 AM
RE: battery power in android - by UnixOutlaw - 08-01-2016, 09:44 PM
RE: battery power in android - by pfeerick - 08-02-2016, 02:55 AM
RE: battery power in android - by UnixOutlaw - 08-03-2016, 02:16 AM
RE: battery power in android - by pfeerick - 08-03-2016, 09:50 PM
RE: battery power in android - by UnixOutlaw - 08-08-2016, 12:40 AM
RE: battery power in android - by pfeerick - 08-08-2016, 02:00 AM
RE: battery power in android - by UnixOutlaw - 08-10-2016, 02:59 AM
RE: battery power in android - by Boring - 08-03-2016, 03:20 AM
RE: battery power in android - by UnixOutlaw - 08-12-2016, 10:32 PM
RE: battery power in android - by pfeerick - 08-13-2016, 02:09 AM
RE: battery power in android - by pfeerick - 08-14-2016, 06:21 PM
RE: battery power in android - by UnixOutlaw - 08-16-2016, 01:58 AM
RE: battery power in android - by pfeerick - 08-17-2016, 01:39 AM
RE: battery power in android - by gperez1234 - 08-31-2016, 07:21 PM
RE: battery power in android - by pfeerick - 08-31-2016, 08:25 PM
RE: battery power in android - by gperez1234 - 09-01-2016, 03:01 AM
RE: battery power in android - by pfeerick - 09-01-2016, 03:17 AM
RE: battery power in android - by dcmorley - 09-01-2016, 04:36 AM
RE: battery power in android - by dcmorley - 09-01-2016, 03:55 PM
RE: battery power in android - by pfeerick - 09-01-2016, 07:36 PM
RE: battery power in android - by dcmorley - 09-14-2016, 05:46 PM
RE: battery power in android - by pfeerick - 09-14-2016, 06:33 PM
RE: battery power in android - by dcmorley - 09-15-2016, 05:10 AM
RE: battery power in android - by MarkHaysHarris777 - 09-15-2016, 11:23 AM
RE: battery power in android - by dcmorley - 09-15-2016, 12:38 PM
RE: battery power in android - by Canyon - 09-20-2016, 11:44 AM
RE: battery power in android - by tllim - 09-20-2016, 06:42 PM
RE: battery power in android - by Canyon - 09-21-2016, 03:11 PM
RE: battery power in android - by tllim - 09-25-2016, 07:54 PM
Rainbow Lithium battery temperature readout? GregH 0 1,899 03-12-2020, 12:05 AM
Last Post: GregH
  Lithium 3.7 Volt Battery Ron Piggott 49 67,517 07-15-2017, 03:56 PM
  Battery level measurement? HugoRabson 2 4,260 03-08-2017, 06:30 PM
Last Post: pfeerick
  Travelling with the Pine64 (and Lipo battery) psychedup 2 4,628 02-17-2017, 08:18 PM
  CR2032 Battery holder - sanity check xalius 23 26,925 01-23-2017, 07:41 PM
Last Post: DonFL
  Battery temp pin? SvdSinner 1 3,877 12-13-2016, 11:35 AM
Last Post: MarkHaysHarris777
  RTC Backup Battery - CR sbentjies 6 9,500 07-15-2016, 06:35 PM
Last Post: jwouellette
  Battery Datasheet xalius 0 2,486 06-20-2016, 07:38 PM
Last Post: xalius
  Lithium 'salt and battery UnixOutlaw 0 2,387 05-29-2016, 09:32 PM
Last Post: UnixOutlaw
  Minor note about the RTC battery MichaelMeissner 12 18,175 02-18-2016, 05:17 AM
Last Post: German
