Travelling with the Pine64 (and Lipo battery)
I sometimes have to travel for work, and I'd love to be able to bring my pine64 with me.
I've heard that LiPo batteries aren't allowed on air travel in the U.S., but I've also heard that only "spare" batteries are banned. The TSA website didn't clear things up, it just says it's up to the agent at the airport whether it's allowed or not. Who wants to wait until they're at the airport to find out they can't bring something?
So I'm just curious if anyone here has travelled on a commercial flight with your Pine + LiPo battery, and if it was allowed?
(02-15-2017, 05:29 PM)psychedup Wrote: I sometimes have to travel for work, and I'd love to be able to bring my pine64 with me.
If your pine is cased and the lipo is installed ( recommend velcro tabs or tape ) you'll get by with it.
I mean , you don't advertise that there is a lipo battery in the case;  and you don't open the case; and you put the pine in your carry on bag.   no problem.   probably.
Having said that, I would leave the lipo at home; lipo batteries are potentially dangerous. IMHO it is irresponsible to travel by air with them. Just take your pine board and your international PSU from RPi; that way you can plug it in wherever you go.
Carry on to flight should be OK, I have done several times. However, check in LiPo battery is prohibited.
  +LTS/SOPINE Powering the A64 LTS from a LiPo belsamber 2 3,377 03-18-2023, 10:05 PM
Last Post: Voidwatcher
Rainbow Lithium battery temperature readout? GregH 0 1,884 03-12-2020, 12:05 AM
Last Post: GregH
  Lithium 3.7 Volt Battery Ron Piggott 49 66,945 07-15-2017, 03:56 PM
  Battery level measurement? HugoRabson 2 4,233 03-08-2017, 06:30 PM
Last Post: pfeerick
  CR2032 Battery holder - sanity check xalius 23 26,653 01-23-2017, 07:41 PM
Last Post: DonFL
  Battery temp pin? SvdSinner 1 3,838 12-13-2016, 11:35 AM
Last Post: MarkHaysHarris777
  battery power in android UnixOutlaw 40 52,106 09-25-2016, 07:54 PM
  RTC Backup Battery - CR sbentjies 6 9,417 07-15-2016, 06:35 PM
Last Post: jwouellette
Question Help sourcing LiPo in Canada pinkelephants 3 5,716 07-14-2016, 08:02 PM
  Battery Datasheet xalius 0 2,471 06-20-2016, 07:38 PM
Last Post: xalius
