02-18-2016, 08:50 AM
I didn't get a good second look at it. Is there a connector attached to the wires or will I need to attach one? Thanks
RTC Backup Battery - CR
02-18-2016, 08:52 AM
(02-18-2016, 08:50 AM)sbentjies Wrote: I didn't get a good second look at it. Is there a connector attached to the wires or will I need to attach one? Thanks Connector will be attached. Please see this thread: http://forum.pine64.org/showthread.php?t...47#pid2447
07-01-2016, 03:51 PM
Can someone recommend a particular PINE A64 RTC-compatible battery, with the proper 2-pin connector, sourced from Amazon, or another reputable online electronics parts store?
regards, J. Ouellette A64-DB-2G-RevB (2016-03-21) +WiFi/BT +IR Android Lollipop Ubuntu/Xenial 16.04LTS/3.10.102-2-pine64-longsleep (64GB) Debian 8.5 (jessie)/MATE 1.8.1/3.10.102-2-pine64-longsleep (64GB)
07-01-2016, 04:17 PM
adafruit has several battery holders & wire with 2pin jst connector
07-05-2016, 03:11 PM
(07-01-2016, 04:17 PM)dkryder Wrote: adafruit has several battery holders & wire with 2pin jst connector Could I also just tape the leads of a JST-PH 2pin connector to a 2032 coin cell and call it a day? Looks like that's what all the RTC batteries for laptops look like on Amazon...
07-06-2016, 04:02 AM
(07-05-2016, 03:11 PM)jwouellette Wrote:(07-01-2016, 04:17 PM)dkryder Wrote: adafruit has several battery holders & wire with 2pin jst connector Yup. You could also do a macgyver, pull the white surround off of the two pin RTC socket, and precariously wedge a CR2032 battery in between the two pins! The moral of the story is you just need to connect a 3v-ish power source to the RTC pins if you want that functionality!
07-15-2016, 06:35 PM
(07-06-2016, 04:02 AM)pfeerick Wrote:(07-05-2016, 03:11 PM)jwouellette Wrote:(07-01-2016, 04:17 PM)dkryder Wrote: adafruit has several battery holders & wire with 2pin jst connector Well, I didn't MacGyver it, but I did install the adafruit pieces with a couple of spade terminals and electrical tape. Seems to be working.... SaveSave
regards, J. Ouellette A64-DB-2G-RevB (2016-03-21) +WiFi/BT +IR Android Lollipop Ubuntu/Xenial 16.04LTS/3.10.102-2-pine64-longsleep (64GB) Debian 8.5 (jessie)/MATE 1.8.1/3.10.102-2-pine64-longsleep (64GB) |
Lithium battery temperature readout? | GregH | 0 | 1,883 |
03-12-2020, 12:05 AM Last Post: GregH |
Lithium 3.7 Volt Battery | Ron Piggott | 49 | 66,901 |
07-15-2017, 03:56 PM Last Post: tllim |
Battery level measurement? | HugoRabson | 2 | 4,229 |
03-08-2017, 06:30 PM Last Post: pfeerick |
Travelling with the Pine64 (and Lipo battery) | psychedup | 2 | 4,587 |
02-17-2017, 08:18 PM Last Post: tllim |
CR2032 Battery holder - sanity check | xalius | 23 | 26,631 |
01-23-2017, 07:41 PM Last Post: DonFL |
Battery temp pin? | SvdSinner | 1 | 3,833 |
12-13-2016, 11:35 AM Last Post: MarkHaysHarris777 |
battery power in android | UnixOutlaw | 40 | 52,076 |
09-25-2016, 07:54 PM Last Post: tllim |
Battery Datasheet | xalius | 0 | 2,470 |
06-20-2016, 07:38 PM Last Post: xalius |
Lithium 'salt and battery | UnixOutlaw | 0 | 2,364 |
05-29-2016, 09:32 PM Last Post: UnixOutlaw |
Minor note about the RTC battery | MichaelMeissner | 12 | 18,004 |
02-18-2016, 05:17 AM Last Post: German |
