Battery Datasheet
Just a quick question, I was looking over the wiki again, but couldn't find the datasheet for the battery from the Pine Shop. It would be really handy to have while looking for something compatible that I dont need to import from China or elsewhere. Thanks :-)
Rainbow Lithium battery temperature readout? GregH 0 1,883 03-12-2020, 12:05 AM
Last Post: GregH
  Lithium 3.7 Volt Battery Ron Piggott 49 66,699 07-15-2017, 03:56 PM
  Battery level measurement? HugoRabson 2 4,226 03-08-2017, 06:30 PM
Last Post: pfeerick
  Travelling with the Pine64 (and Lipo battery) psychedup 2 4,581 02-17-2017, 08:18 PM
  CR2032 Battery holder - sanity check xalius 23 26,623 01-23-2017, 07:41 PM
Last Post: DonFL
  Battery temp pin? SvdSinner 1 3,829 12-13-2016, 11:35 AM
Last Post: MarkHaysHarris777
  battery power in android UnixOutlaw 40 52,000 09-25-2016, 07:54 PM
  RTC Backup Battery - CR sbentjies 6 9,394 07-15-2016, 06:35 PM
Last Post: jwouellette
  Lithium 'salt and battery UnixOutlaw 0 2,364 05-29-2016, 09:32 PM
Last Post: UnixOutlaw
  Minor note about the RTC battery MichaelMeissner 12 17,988 02-18-2016, 05:17 AM
Last Post: German
