battery power in android
#21
(08-13-2016, 02:09 AM)pfeerick Wrote:
(08-12-2016, 11:07 PM)MarkHaysHarris777 Wrote:
(08-12-2016, 10:32 PM)UnixOutlaw Wrote: OK - so I've got 10 x 10K resistors from RS - which side/end does the "resistance"?  Dumb newb question I know - but - as previously stated - I'm colour blind - and never done this kinda stuff before... :-)
i.e. which end do I point at the middle pin of Pine's battery input?  the gold end - or the end with two darker stripes (I can't tell what colour they are)?
hi, resistors are not 'directional'  like a diode is.  Put it in either direction, does not matter.  The 10K resistor connects to the center pin, and runs to ground.  The positive RED wire goes in VBAT+  and the black  negative wire goes in VBAT-
What Mark said Smile And please don't tell us you can't tell the difference between red and black (as you said you were colour blind)... otherwise I'll start to cry knowing a pine64 is about to suffer it's demise (50/50 chance) :Big Grin
Well, my generic 8000mah battery seems to be no-where near it's rated capacity - is lasting about half the time I would have liked (basically overnight). I had intended to make it so the pine64 was charged from solar when the sun was up, and run from the battery overnight, but the battery is only just making it overnight, so won't last long with that near total usage, and doesn't leave any room for the pine64 do actually do some work.... this was with the pine64 idling.
So much for 8000 / 300 = 26 hours (or 20 hours if you base it on a 400ma load). Either this battery is not up to spec (likely), and/or the pine64 is lying about it's power consumption (also possible). I'm getting 15 hours of runtime (and it saying 3% capacity when the power cuts back in!!!), so not happy jan! Maybe I'll have to strap on a second cell in parallel give it the capacity bump it needs. I'm liking the idea of using 18650 cells in holders... 5 or 6 of those at 2200mah should do the trick (and be about the same size as the pine64 to boot!
If you read this thread from the start - then you'd already be aware I have already wired up a battery to Pine - and got Android to show them charging - but being unable to actually power Pine off a battery (dies when I pull micro USB power from it).
Yes - in ideal lighting conditions - I can distinguish black from red...
And as for tears, I have a love hate relationship with Pine - and one day I may end up deliberately smashing one of my boards and shed tears of pure savage delight :-)
Anyway - going to test tonight, or tomorrow morning, whether any of my batteries with PH3 connectors + 10 K resistor to middle pin, will actually power Pine64, or not...   Right now Android is the only resource I have for testing, really hanging out for a Linux build that supports the Pine branded 7" touchpanel...
battery power in android - by UnixOutlaw - 07-31-2016, 02:54 AM
RE: battery power in android - by xalius - 07-31-2016, 03:36 AM
RE: battery power in android - by UnixOutlaw - 07-31-2016, 05:29 AM
RE: battery power in android - by xalius - 07-31-2016, 05:36 AM
RE: battery power in android - by UnixOutlaw - 08-01-2016, 09:44 PM
RE: battery power in android - by pfeerick - 08-02-2016, 02:55 AM
RE: battery power in android - by UnixOutlaw - 08-03-2016, 02:16 AM
RE: battery power in android - by pfeerick - 08-03-2016, 09:50 PM
RE: battery power in android - by UnixOutlaw - 08-08-2016, 12:40 AM
RE: battery power in android - by pfeerick - 08-08-2016, 02:00 AM
RE: battery power in android - by UnixOutlaw - 08-10-2016, 02:59 AM
RE: battery power in android - by Boring - 08-03-2016, 03:20 AM
RE: battery power in android - by UnixOutlaw - 08-12-2016, 10:32 PM
RE: battery power in android - by pfeerick - 08-13-2016, 02:09 AM
RE: battery power in android - by pfeerick - 08-14-2016, 06:21 PM
RE: battery power in android - by UnixOutlaw - 08-16-2016, 01:58 AM
RE: battery power in android - by pfeerick - 08-17-2016, 01:39 AM
RE: battery power in android - by gperez1234 - 08-31-2016, 07:21 PM
RE: battery power in android - by pfeerick - 08-31-2016, 08:25 PM
RE: battery power in android - by gperez1234 - 09-01-2016, 03:01 AM
RE: battery power in android - by pfeerick - 09-01-2016, 03:17 AM
RE: battery power in android - by dcmorley - 09-01-2016, 04:36 AM
RE: battery power in android - by dcmorley - 09-01-2016, 03:55 PM
RE: battery power in android - by pfeerick - 09-01-2016, 07:36 PM
RE: battery power in android - by dcmorley - 09-14-2016, 05:46 PM
RE: battery power in android - by pfeerick - 09-14-2016, 06:33 PM
RE: battery power in android - by dcmorley - 09-15-2016, 05:10 AM
RE: battery power in android - by dcmorley - 09-15-2016, 12:38 PM
RE: battery power in android - by Canyon - 09-20-2016, 11:44 AM
RE: battery power in android - by tllim - 09-20-2016, 06:42 PM
RE: battery power in android - by Canyon - 09-21-2016, 03:11 PM
RE: battery power in android - by tllim - 09-25-2016, 07:54 PM
Rainbow Lithium battery temperature readout? GregH 0 1,887 03-12-2020, 12:05 AM
Last Post: GregH
  Lithium 3.7 Volt Battery Ron Piggott 49 67,024 07-15-2017, 03:56 PM
  Battery level measurement? HugoRabson 2 4,237 03-08-2017, 06:30 PM
Last Post: pfeerick
  Travelling with the Pine64 (and Lipo battery) psychedup 2 4,598 02-17-2017, 08:18 PM
  CR2032 Battery holder - sanity check xalius 23 26,704 01-23-2017, 07:41 PM
Last Post: DonFL
  Battery temp pin? SvdSinner 1 3,850 12-13-2016, 11:35 AM
Last Post: MarkHaysHarris777
  RTC Backup Battery - CR sbentjies 6 9,425 07-15-2016, 06:35 PM
Last Post: jwouellette
  Battery Datasheet xalius 0 2,474 06-20-2016, 07:38 PM
Last Post: xalius
  Lithium 'salt and battery UnixOutlaw 0 2,371 05-29-2016, 09:32 PM
Last Post: UnixOutlaw
  Minor note about the RTC battery MichaelMeissner 12 18,041 02-18-2016, 05:17 AM
Last Post: German
