battery power in android
(08-13-2016, 02:09 AM)pfeerick Wrote: Well, my generic 8000mah battery seems to be no-where near it's rated capacity - is lasting about half the time I would have liked (basically overnight). I had intended to make it so the pine64 was charged from solar when the sun was up, and run from the battery overnight, but the battery is only just making it overnight, so won't last long with that near total usage, and doesn't leave any room for the pine64 do actually do some work.... this was with the pine64 idling.
hi pfeerick, I am working with SLA batts at the moment. I posted in the DC POWERIN subforum;  I'm using the CPT module I received from Pine. I built a low_pass filter ( PI ) and have been playing around with powering via 12v on via CPT via PI filter on the euler buss.
My interest of course is robotics.  I need some beefy batts for the 12v motors I'm going to use, plus I need it to keep the electronics up (for several hours, while the robot patrols the house).
But, I was thinking the 12v system is the answer to a solar system also. The lith-ion batts aren't going to cut it, but a bank of 12v SLA batts I think is just the ticket.   Let me know what you think.
battery power in android - by UnixOutlaw - 07-31-2016, 02:54 AM
RE: battery power in android - by xalius - 07-31-2016, 03:36 AM
RE: battery power in android - by UnixOutlaw - 07-31-2016, 05:29 AM
RE: battery power in android - by xalius - 07-31-2016, 05:36 AM
RE: battery power in android - by UnixOutlaw - 08-01-2016, 09:44 PM
RE: battery power in android - by pfeerick - 08-02-2016, 02:55 AM
RE: battery power in android - by UnixOutlaw - 08-03-2016, 02:16 AM
RE: battery power in android - by pfeerick - 08-03-2016, 09:50 PM
RE: battery power in android - by UnixOutlaw - 08-08-2016, 12:40 AM
RE: battery power in android - by pfeerick - 08-08-2016, 02:00 AM
RE: battery power in android - by UnixOutlaw - 08-10-2016, 02:59 AM
RE: battery power in android - by Boring - 08-03-2016, 03:20 AM
RE: battery power in android - by UnixOutlaw - 08-12-2016, 10:32 PM
RE: battery power in android - by pfeerick - 08-13-2016, 02:09 AM
RE: battery power in android - by MarkHaysHarris777 - 08-13-2016, 02:20 AM
RE: battery power in android - by pfeerick - 08-14-2016, 06:21 PM
RE: battery power in android - by UnixOutlaw - 08-16-2016, 01:58 AM
RE: battery power in android - by pfeerick - 08-17-2016, 01:39 AM
RE: battery power in android - by gperez1234 - 08-31-2016, 07:21 PM
RE: battery power in android - by pfeerick - 08-31-2016, 08:25 PM
RE: battery power in android - by gperez1234 - 09-01-2016, 03:01 AM
RE: battery power in android - by pfeerick - 09-01-2016, 03:17 AM
RE: battery power in android - by dcmorley - 09-01-2016, 04:36 AM
RE: battery power in android - by dcmorley - 09-01-2016, 03:55 PM
RE: battery power in android - by pfeerick - 09-01-2016, 07:36 PM
RE: battery power in android - by dcmorley - 09-14-2016, 05:46 PM
RE: battery power in android - by pfeerick - 09-14-2016, 06:33 PM
RE: battery power in android - by dcmorley - 09-15-2016, 05:10 AM
RE: battery power in android - by dcmorley - 09-15-2016, 12:38 PM
RE: battery power in android - by Canyon - 09-20-2016, 11:44 AM
RE: battery power in android - by tllim - 09-20-2016, 06:42 PM
RE: battery power in android - by Canyon - 09-21-2016, 03:11 PM
RE: battery power in android - by tllim - 09-25-2016, 07:54 PM
Rainbow Lithium battery temperature readout? GregH 0 1,899 03-12-2020, 12:05 AM
Last Post: GregH
  Lithium 3.7 Volt Battery Ron Piggott 49 67,510 07-15-2017, 03:56 PM
  Battery level measurement? HugoRabson 2 4,260 03-08-2017, 06:30 PM
Last Post: pfeerick
  Travelling with the Pine64 (and Lipo battery) psychedup 2 4,628 02-17-2017, 08:18 PM
  CR2032 Battery holder - sanity check xalius 23 26,925 01-23-2017, 07:41 PM
Last Post: DonFL
  Battery temp pin? SvdSinner 1 3,877 12-13-2016, 11:35 AM
Last Post: MarkHaysHarris777
  RTC Backup Battery - CR sbentjies 6 9,493 07-15-2016, 06:35 PM
Last Post: jwouellette
  Battery Datasheet xalius 0 2,486 06-20-2016, 07:38 PM
Last Post: xalius
  Lithium 'salt and battery UnixOutlaw 0 2,387 05-29-2016, 09:32 PM
Last Post: UnixOutlaw
  Minor note about the RTC battery MichaelMeissner 12 18,161 02-18-2016, 05:17 AM
Last Post: German
