battery power in android
(08-01-2016, 09:44 PM)UnixOutlaw Wrote: Okay - so I flipped over the jumper - to the other poles - and still no go...
Powers up on USB DC in - battery shows connected and charged - pull USB power out and the thing goes black!
Is this a software thing?  What gives?  What's the point of charging a battery if you can't run on it?
I'm yet to test in Linux - but I will be mighty annoyed if I can't run either of my Pines on battery!
Also - are there any AXP (I think I read somewhere about Pine using AXP209) scripts to monitor battery from Linux?
I can't comment as to whether the pine64 will run if booted with DC connected, and then is yanked, but I can say that I was able to power the pine64 from the battery without any drama... oh, wait... does your battery have a three pin connector? If not, you need to connect the middle pin to ground via a 10k resistor (there is an obscure reference to this on p6 of the datasheet, plus tllim stated that here
If you have a two wire battery, and the middle pin is not connected to GND via the resistor, the AXP803 will think there is something wrong with the battery and refuse to use it (or even charge it IIRC).
There is one or two battery monitor scripts knocking around... I made this one colourful one based off of one of the ones knocking around on the forum somewhere.
battery power in android - by UnixOutlaw - 07-31-2016, 02:54 AM
RE: battery power in android - by xalius - 07-31-2016, 03:36 AM
RE: battery power in android - by UnixOutlaw - 07-31-2016, 05:29 AM
RE: battery power in android - by xalius - 07-31-2016, 05:36 AM
RE: battery power in android - by UnixOutlaw - 08-01-2016, 09:44 PM
RE: battery power in android - by pfeerick - 08-02-2016, 02:55 AM
RE: battery power in android - by UnixOutlaw - 08-03-2016, 02:16 AM
RE: battery power in android - by pfeerick - 08-03-2016, 09:50 PM
RE: battery power in android - by UnixOutlaw - 08-08-2016, 12:40 AM
RE: battery power in android - by pfeerick - 08-08-2016, 02:00 AM
RE: battery power in android - by UnixOutlaw - 08-10-2016, 02:59 AM
RE: battery power in android - by Boring - 08-03-2016, 03:20 AM
RE: battery power in android - by UnixOutlaw - 08-12-2016, 10:32 PM
RE: battery power in android - by pfeerick - 08-13-2016, 02:09 AM
RE: battery power in android - by pfeerick - 08-14-2016, 06:21 PM
RE: battery power in android - by UnixOutlaw - 08-16-2016, 01:58 AM
RE: battery power in android - by pfeerick - 08-17-2016, 01:39 AM
RE: battery power in android - by gperez1234 - 08-31-2016, 07:21 PM
RE: battery power in android - by pfeerick - 08-31-2016, 08:25 PM
RE: battery power in android - by gperez1234 - 09-01-2016, 03:01 AM
RE: battery power in android - by pfeerick - 09-01-2016, 03:17 AM
RE: battery power in android - by dcmorley - 09-01-2016, 04:36 AM
RE: battery power in android - by dcmorley - 09-01-2016, 03:55 PM
RE: battery power in android - by pfeerick - 09-01-2016, 07:36 PM
RE: battery power in android - by dcmorley - 09-14-2016, 05:46 PM
RE: battery power in android - by pfeerick - 09-14-2016, 06:33 PM
RE: battery power in android - by dcmorley - 09-15-2016, 05:10 AM
RE: battery power in android - by dcmorley - 09-15-2016, 12:38 PM
RE: battery power in android - by Canyon - 09-20-2016, 11:44 AM
RE: battery power in android - by tllim - 09-20-2016, 06:42 PM
RE: battery power in android - by Canyon - 09-21-2016, 03:11 PM
RE: battery power in android - by tllim - 09-25-2016, 07:54 PM
Rainbow Lithium battery temperature readout? GregH 0 1,897 03-12-2020, 12:05 AM
Last Post: GregH
  Lithium 3.7 Volt Battery Ron Piggott 49 67,383 07-15-2017, 03:56 PM
  Battery level measurement? HugoRabson 2 4,255 03-08-2017, 06:30 PM
Last Post: pfeerick
  Travelling with the Pine64 (and Lipo battery) psychedup 2 4,623 02-17-2017, 08:18 PM
  CR2032 Battery holder - sanity check xalius 23 26,836 01-23-2017, 07:41 PM
Last Post: DonFL
  Battery temp pin? SvdSinner 1 3,865 12-13-2016, 11:35 AM
Last Post: MarkHaysHarris777
  RTC Backup Battery - CR sbentjies 6 9,465 07-15-2016, 06:35 PM
Last Post: jwouellette
  Battery Datasheet xalius 0 2,482 06-20-2016, 07:38 PM
Last Post: xalius
  Lithium 'salt and battery UnixOutlaw 0 2,382 05-29-2016, 09:32 PM
Last Post: UnixOutlaw
  Minor note about the RTC battery MichaelMeissner 12 18,119 02-18-2016, 05:17 AM
Last Post: German
