Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating
(11-05-2023, 01:25 PM)marty-mcfly Wrote: Thank you for posting this! I also have a PBPro and have been loving it!
I am on latest Manjaro Arm KDE - generic image.  WiFi and Bluetooth work great as long as I shutdown and then power on. It won't work if I reboot.
Unfortunately, I have been unable to hook up an external display via the usb-c output.
I'm wondering what you did to enable output to an external display.
What image are you using and what kernel are you using?
Thanks again!
Hello!
Sorry for the late response.
I used this procedure to enable an external display, but just bear in mind my above experience Smile
I think the answers to the other two questions you had are answered there as well, but I'm using Megi's kernel/image located here (using pbpro.tar.gz). but the version I'm using right now is 6.5.7-00508-gb1f5e9cc01a2.
RE: Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating - by trifleneurotic - 11-14-2023, 10:57 AM
  Manjaro Sway Theme Broken Eighty8 1 312 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,787 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 368 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,209 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,289 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 436 12-07-2023, 03:11 PM
  No external monitorvia USB-C over Dockingstation bnjmnhg 14 3,148 11-28-2023, 01:35 PM
Last Post: zaius
  Sleep and external display - Are there any options? chris88233 7 1,792 09-04-2023, 09:03 PM
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,046 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,011 08-21-2023, 09:08 PM
