Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating
Hey all! First post here.
I'll keep it quick, but before I start I want to say that I have a workaround and I'm OK with it, although I'd like to have a "cleaner" solution in place if possible.
Long and short of it: Just received my Pinebook Pro a few days ago with Manjaro ARM. All was well until I found out that the version Manjaro I had didn't support external monitors at all, due to patch not being in mainline. Tried different monitors, different cables, rotating cables, etc. No dice.
So I switched to a custom kernel to fix that problem, however that knocked out my WiFi. OS wouldn't even acknowledge that hardware was there. I thought it may have been hardware failure until I starting finding errors about loading Broadcom firmware in dmesg.
I tried the usual suspects such as ensuring /boot was properly mounted, cold booting, privacy switch, etc. Nothing. Reverting back to the original kernel made no difference either.
After many hours of trial & error and searching for answers, I found a set of firmware files which worked when placed in the proper location, but it wasn't "plug-and-play" so to speak. Every time now when I want to use WiFi after booting, I have to use that "(un)bind" trick:
sudo tee /sys/bus/platform/drivers/dwmmc_rockchip/{un,}bind <<< 'fe310000.mmc'
I never touched the Broadcom firmware files before my kernel update and later before my reversion. Thought maybe something was compiled into the stock kernel to enable WiFi, so I can't explain why WiFi still didn't work when I reverted. So I could be missing something there.
I can have that command line above automatically run on boot, no problem.
Wanted to share my experience, help others out if they run into this, and also ask if there is anything I can do to not have to run that command on every boot.
I'm in a Good Place now, and still enjoying PBPro. Look forward to testing as my daily driver!
Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating - by trifleneurotic - 11-01-2023, 09:05 AM
  Manjaro Sway Theme Broken Eighty8 1 312 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,787 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 365 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,209 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,288 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 433 12-07-2023, 03:11 PM
  No external monitorvia USB-C over Dockingstation bnjmnhg 14 3,147 11-28-2023, 01:35 PM
Last Post: zaius
  Sleep and external display - Are there any options? chris88233 7 1,788 09-04-2023, 09:03 PM
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,046 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,010 08-21-2023, 09:08 PM
