"failed to start simple desktop display manager" PinePhonePro / Plasma Beta15 RC4
I have a "recent" version of the PinePhonePro (i.e. - there is no RE button.)
Tow-Boot was pre-installed and seems to be working fine.
I don't know what's flashed on the eMMC in the factory, but when I tried to update it, replaced pacman pgp signatures with HTML advertisements for domains for sale (that's a new one.)
But I deleted the .sigs and updated through discovery.
I then got some sort of error on boot, but couldn't quite make it out because I couldn't turn on the backlight.  But the system didn't boot to a graphical screen.
I then downloaded Manjaro-ARM-plasma-mobile-pinephonepro-beta15-rc4.img.xz from https://github.com/manjaro-pinephone/pla...e/releases
Flashed it to eMMC using tow-boot and rebooted.
Other than it setting the backlight to zero on boot, everything was fine. screen worked. audio worked. wifi worked. i was able to activate sshd via systemctl.  I was completely happy.
But I did want to add software and update the device.
So...
sudo rm -r /etc/pacman.d/gnupg
sudo pacman-mirrors --geoip
sudo pacman -Sy gnupg archlinux-keyring archlinuxarm-keyring manjaro-keyring manjaro-arm-keyring
sudo pacman-key --init
sudo pacman-key --populate
sudo pacman-key --refresh-keys
sudo pacman -Sc
and then
sudo pacman -Syyuu
and it downloaded about 900Mb of new packages.  But now when I reboot, it hang w/ a message "failed to start simple desktop display manager" (I figured out that you set the screen dim timeout to never or some large value to avoid having the screen super-dim when it reboots.)
is this the expected behaviour?  are we just not supposed to update?  anyone have references to pages describing how to fix this?
"failed to start simple desktop display manager" PinePhonePro / Plasma Beta15 RC4 - by OhMeadhbh - 10-20-2023, 12:24 PM
  [WIP] KDE Plasma Mobile 6.0 Builds & Ports dorkydev 5 760 04-15-2024, 08:08 AM
Last Post: u-kidjp
  Mobian .desktop file creation MadameMalady 15 3,386 07-27-2023, 04:12 PM
Last Post: MadameMalady
  Manajaro Plasma 6 files break unstable updates, 6-30 mburns 5 1,674 07-20-2023, 11:19 AM
Last Post: mburns
  My Waydroid Manager call for testers / assistance MadameMalady 0 693 07-15-2023, 02:16 PM
  Manjaro Plasma unstable branch glitch mburns 2 1,113 06-21-2023, 08:03 AM
Last Post: mburns
  Phosh Updating - Battery Charge Indicator - Jittery Settings - Display Usability ArchiMark 4 1,480 05-28-2023, 07:00 AM
Last Post: ArchiMark
  Is Manjaro Plasma stable for anyone? projectcato 120 54,919 04-18-2023, 08:26 PM
Last Post: mburns
  Plasma Mobile Taskbar / Navigation Bar is Missing & Upper Panel X0X0X0X0X0 1 1,343 11-24-2022, 07:19 AM
Last Post: mburns
  PinePhone Pro Manjaro Plasma Mobile Beta 13 & No Audio with Phone Calls X0X0X0X0X0 0 1,122 11-02-2022, 02:09 PM
Last Post: X0X0X0X0X0
  Monjaro Plasma Cell Network and Data not working properly maiyuzhe 2 1,629 09-24-2022, 12:15 AM
Last Post: maiyuzhe
