CR2032 Battery holder - sanity check
#24
Yes, using batteries of questionable or unknown quality/output might cause you issues, but if in parallel not anything that really worries me.
Key point here is..assembled correctly, either one battery or two will work. If using two batteries, ensure correct assembly and verify you have 3V on the connector pins (and not 6V, suggesting they are in series, or a minimal voltage output indicating they are connected with opposite polarity, or bucking), and you're fine.
CR2032 Battery holder - sanity check - by xalius - 07-22-2016, 04:30 PM
RE: CR2032 Battery holder - sanity check - by DonFL - 01-23-2017, 07:41 PM
Rainbow Lithium battery temperature readout? GregH 0 1,899 03-12-2020, 12:05 AM
Last Post: GregH
  Lithium 3.7 Volt Battery Ron Piggott 49 67,463 07-15-2017, 03:56 PM
  Battery level measurement? HugoRabson 2 4,258 03-08-2017, 06:30 PM
Last Post: pfeerick
  Travelling with the Pine64 (and Lipo battery) psychedup 2 4,625 02-17-2017, 08:18 PM
  Battery temp pin? SvdSinner 1 3,868 12-13-2016, 11:35 AM
Last Post: MarkHaysHarris777
  battery power in android UnixOutlaw 40 52,572 09-25-2016, 07:54 PM
  RTC Backup Battery - CR sbentjies 6 9,478 07-15-2016, 06:35 PM
Last Post: jwouellette
  Battery Datasheet xalius 0 2,482 06-20-2016, 07:38 PM
Last Post: xalius
  Lithium 'salt and battery UnixOutlaw 0 2,384 05-29-2016, 09:32 PM
Last Post: UnixOutlaw
  Minor note about the RTC battery MichaelMeissner 12 18,126 02-18-2016, 05:17 AM
Last Post: German
