CR2032 Battery holder - sanity check
(07-23-2016, 05:35 PM)@lex Wrote:
(07-23-2016, 05:33 PM)DonFL Wrote:
(07-23-2016, 05:25 PM)@lex Wrote: I mean two CR2032 (3v), the left coin (near the cable) (+) facing up, the second CR2032 (3v)  (-) facing up.
That puts them in series, giving you 6V rather than 3 as we are confident is correct. If you look at the scehmatic, there doesn't appear to be any on-board regulation for the RTC, so you're feeding that pin on the PMIC with 6V, spec appears to be 3V max.
I would tend to agree with xalius that the holder is mis-marked.
I mesured at the conector, it is 2.85v, so it is not feeding with 6v.
When you measure the output of the battery holder, not connected to the board, what do you see? 6V?
And then when you plug it in, where are you taking your measurement?
CR2032 Battery holder - sanity check - by xalius - 07-22-2016, 04:30 PM
RE: CR2032 Battery holder - sanity check - by DonFL - 07-23-2016, 05:46 PM
Rainbow Lithium battery temperature readout? GregH 0 1,905 03-12-2020, 12:05 AM
Last Post: GregH
  Lithium 3.7 Volt Battery Ron Piggott 49 67,713 07-15-2017, 03:56 PM
  Battery level measurement? HugoRabson 2 4,271 03-08-2017, 06:30 PM
Last Post: pfeerick
  Travelling with the Pine64 (and Lipo battery) psychedup 2 4,643 02-17-2017, 08:18 PM
  Battery temp pin? SvdSinner 1 3,884 12-13-2016, 11:35 AM
Last Post: MarkHaysHarris777
  battery power in android UnixOutlaw 40 52,895 09-25-2016, 07:54 PM
  RTC Backup Battery - CR sbentjies 6 9,534 07-15-2016, 06:35 PM
Last Post: jwouellette
  Battery Datasheet xalius 0 2,490 06-20-2016, 07:38 PM
Last Post: xalius
  Lithium 'salt and battery UnixOutlaw 0 2,392 05-29-2016, 09:32 PM
Last Post: UnixOutlaw
  Minor note about the RTC battery MichaelMeissner 12 18,219 02-18-2016, 05:17 AM
Last Post: German
