CR2032 Battery holder - sanity check
(07-23-2016, 05:25 PM)@lex Wrote: I mean two CR2032 (3v), the left coin (near the cable) (+) facing up, the second CR2032 (3v) (-) facing up.
That puts them in series, giving you 6V rather than 3 as we are confident is correct. If you look at the scehmatic, there doesn't appear to be any on-board regulation for the RTC, so you're feeding that pin on the PMIC with 6V, spec appears to be 3V max.
I would tend to agree with xalius that the holder is mis-marked.
CR2032 Battery holder - sanity check - by xalius - 07-22-2016, 04:30 PM
RE: CR2032 Battery holder - sanity check - by DonFL - 07-23-2016, 05:33 PM
Rainbow Lithium battery temperature readout? GregH 0 1,903 03-12-2020, 12:05 AM
Last Post: GregH
  Lithium 3.7 Volt Battery Ron Piggott 49 67,676 07-15-2017, 03:56 PM
  Battery level measurement? HugoRabson 2 4,270 03-08-2017, 06:30 PM
Last Post: pfeerick
  Travelling with the Pine64 (and Lipo battery) psychedup 2 4,640 02-17-2017, 08:18 PM
  Battery temp pin? SvdSinner 1 3,881 12-13-2016, 11:35 AM
Last Post: MarkHaysHarris777
  battery power in android UnixOutlaw 40 52,864 09-25-2016, 07:54 PM
  RTC Backup Battery - CR sbentjies 6 9,522 07-15-2016, 06:35 PM
Last Post: jwouellette
  Battery Datasheet xalius 0 2,488 06-20-2016, 07:38 PM
Last Post: xalius
  Lithium 'salt and battery UnixOutlaw 0 2,390 05-29-2016, 09:32 PM
Last Post: UnixOutlaw
  Minor note about the RTC battery MichaelMeissner 12 18,212 02-18-2016, 05:17 AM
Last Post: German
