02-07-2023, 04:27 PM
(02-07-2023, 01:38 PM)anonymous Wrote: I'm really upset. I've spent hours in installing Mobian, I refused the theme change on Plymouth this time (to verify whether it helps or not) but when I reboot, I have the same problem, the screen is almost black after the login. The problem is that I'm forced to reboot frequently because of crashes occurring randomly, it's the only workaround I've found. I had to reboot because Gnome control settings application crashed when I tried to choose a language. Now I'm stuck. I'm fed up, I need a solution. I'll try to redo the install without upgrading. I'm very disappointed. It leads to nowhere, my mobile phone is becoming unusable.
Someone wrote "disable greetd and enable phosh" on the Matrix channel. I'm investigating.
I have to reinstall everything once again, I'll try this suggestion:
to do it immediatelyCode:sudo systemctl start phosh && sudo systemctl stop greetd
to set it from the next boot foreverCode:sudo systemctl disable greetd && sudo systemctl enable phosh
I thank Marco for the tip.
I confirm that Marco's advice works, my problem has been solved.
