Impossible to login since the latest update
(02-07-2023, 08:03 AM)dante404 Wrote: Stupid question: Turning off (perhaps even temporary remove battery) and on again doesn't help I guess?
Second (better) question: Did you have SSH enabled on the PinePhone? Or have a serial debugger cable?
I'll try your first suggestion.
I don't enable SSH for security reasons, full disk encryption is enabled. I have no serial debugger cable. However, Tow-boot works, I can access my files. If no solution can be found, I'll have to reinstall Mobian, convert the sqlite file containing my contacts into vcf, import my contacts with Evolution, copy Chatty sqlite file containing my messages (SMS and MMS), copy the directory containing my MMS files, install nemo, copy the MMS settings so that I can at least receive MMS and enter the two APNs (Internet + MMS). A better solution would be welcome but I guess it's expected as the software is still pre-beta and I won't buy an Android smartphone.
RE: Impossible to login since the latest update - by anonymous - 02-07-2023, 09:19 AM
  Auto start application on Phosh login Zebulon Walton 8 3,547 10-14-2023, 06:29 AM
Last Post: alaraajavamma
  No volume control after latest updates Zebulon Walton 19 7,410 09-08-2023, 08:28 AM
Last Post: jessencan
  how to update mobian over tor vusra 13 7,129 07-09-2023, 08:57 PM
Last Post: vusra
  Wifi doesn't work after update nickolas 2 1,291 04-14-2023, 10:07 AM
Last Post: nickolas
  PinePhone won't boot after software update jb2000 2 1,391 03-17-2023, 07:26 AM
Exclamation The latest update of eg25-manager seems to cause frequent disconnections anonymous 12 4,511 11-28-2022, 03:30 PM
Last Post: anonymous
  [Fixed] Phosh crashes frequently after latest updates arno_nuehm 20 9,174 10-14-2022, 05:38 PM
Last Post: Krafter
  Latest Reliable Mobian Build Confirmation Thread Katsujinken 5 2,768 09-27-2022, 08:41 AM
Last Post: Katsujinken
  Wifi issue since last update and held back updates goku499 11 5,524 09-21-2022, 02:39 PM
  [SOLVED] Lost Internet connectivity after recent update drh 3 1,940 09-11-2022, 09:24 PM
