Issue with booting Manjaro from encrypted NVMe drive on pbp
I think you should check the initramfs hooks: Confirm that the necessary hooks
plymouth, plymouth-encrypt, and lvm2
pizza tower
are correctly included in the initramfs. You mentioned that you built the initramfs using mkinitcpio from within the system. Make sure that the hooks are specified in the /etc/mkinitcpio.conf file. You can check the contents of this file to ensure that the hooks are listed correctly.
RE: Issue with booting Manjaro from encrypted NVMe drive on pbp - by juliamenendez - 08-18-2023, 01:58 AM
  Manjaro Sway Theme Broken Eighty8 1 290 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,762 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 336 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,153 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,232 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 413 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 905 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,024 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,982 08-21-2023, 09:08 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 772 08-18-2023, 02:06 AM
Last Post: juliamenendez
