Latest Manjaro Update fails HDMI
After updating a Rock64 Ver. 2 board running Manjaro/Plasma, and running update, and then the obligatory reboot, the HDMI output was/is broken. The original system is as follows:
Operating System: Manjaro-ARM
KDE Plasma Version: 5.24.4
KDE Frameworks Version: 5.92.0
Qt Version: 5.15.3
Kernel Version: 5.17.1-4-MANJARO-ARM (64-bit)
Graphics Platform: X11
Processors: 4 × ARM Cortex-A53
Memory: 3.9 GiB of RAM
Graphics Processor: Mali450
I've downloaded the version labeled "Manjaro-ARM-gnome-rock64-22.06.img" and it creates the same issue. When I return to the older version HDMI is fine again. Then the system notifies that updates are required and the cycle begins again Confused
Anyone know of a solution?
As an update I've imaged the Armbian OS and booted from the SD fine. Then manually updated the system. Again it booted up fine. The only problem so far is the HDMI output flickering. It increases when system activity increases. For example; rolling the mouse over desktop icons will cause the screen to flicker. If the system sits idle the video stabilizes but if ANY activity is introduced, the flicker begins again. This makes it difficult to do anything with it. So in essence neither of these OS's are usable as indicated.
Latest Manjaro Update fails HDMI - by Flagtrax - 01-06-2023, 10:47 AM
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,576 01-17-2023, 02:31 PM
Last Post: Flagtrax
  HDMI noise on Rock64 ab1jx 1 2,900 06-19-2020, 04:54 PM
Last Post: ab1jx
  Hoe to Update Buildroot Package config from SDK build.sh file shivarj89 0 1,720 09-09-2019, 09:39 AM
Last Post: shivarj89
  HDMI 2.0a CEC compliancy issue? Willem53 1 2,526 04-13-2019, 08:02 AM
Last Post: Willem53
Photo HDMI resolution bueschi 0 2,156 01-06-2019, 02:34 PM
Last Post: bueschi
  Odd HDMI issues jman005 0 1,805 10-26-2018, 09:15 PM
Last Post: jman005
  HDMI Signal strength bennettjp 3 3,861 09-18-2018, 12:59 PM
Last Post: Luke
  rock64 hdmi power (dpms like, no xrandr) asavah 0 1,839 06-28-2018, 11:09 AM
Last Post: asavah
  HDMI-CEC issue after TV restarting Sahab 4 3,908 02-09-2018, 01:21 PM
Last Post: Sahab
  Firmware update for the Rock64 mcrognale 1 4,160 11-29-2017, 03:18 PM
Last Post: Luke
