HDMI Signal strength
Hello all,
Recently my office picked up several Rock64 boards to be used for a network monitoring wall project. We have two network walls, the first consists of 3 50" televisions and the second consists of 4 55" televisions. I noticed that when using very long HDMI cables, in our case 50 ft, the hdmi signal is too weak and the TV displays no signal.
Is there a config_hdmi_boost value that I can modify like on the Raspberry Pi?
I know that the best case scenario is to mount the board to the back of the television and use a short cable. Our network wall already had four 50 ft and three 25 ft HDMI cables run in the ceiling of our office.
Thanks,
Possibly in extlinux. I'll check and get back to you.
Thank you. I forgot to mention we are using the following:
Debian 9.5 Stretch with MATE Desktop 1.16.2
(09-18-2018, 09:55 AM)bennettjp Wrote: Thank you. I forgot to mention we are using the following:
Which image exactly? Could you try 0.7.9 LXDE Ubuntu (Bionic) just for the sake of testing? thanks.
I haven't yet determined how to 'boost' HDMI strength in extlinux
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,519 01-17-2023, 02:31 PM
Last Post: Flagtrax
  Latest Manjaro Update fails HDMI Flagtrax 0 561 01-06-2023, 10:47 AM
Last Post: Flagtrax
  Safest way to send shutdown signal to headless Rock64 SMB server? bmurphr1 3 4,221 03-14-2021, 06:01 PM
Last Post: clach04
  HDMI noise on Rock64 ab1jx 1 2,874 06-19-2020, 04:54 PM
Last Post: ab1jx
Photo Has anyone been able to get a signal from the av/composite/cvbs port? bestpc 2 3,822 09-17-2019, 12:51 PM
Last Post: bestpc
  HDMI 2.0a CEC compliancy issue? Willem53 1 2,502 04-13-2019, 08:02 AM
Last Post: Willem53
Photo HDMI resolution bueschi 0 2,141 01-06-2019, 02:34 PM
Last Post: bueschi
  Odd HDMI issues jman005 0 1,790 10-26-2018, 09:15 PM
Last Post: jman005
Sad Rock64 2GB Version Can't output 4K Signal leonqin 1 2,597 08-18-2018, 05:59 PM
Last Post: leonqin
  rock64 hdmi power (dpms like, no xrandr) asavah 0 1,826 06-28-2018, 11:09 AM
Last Post: asavah
