What OS have you recently flashed onto PBP eMMC?
How would you back up the eMMC? Would you boot from SD and then copy the eMMC's contents?
Yeah I assumed (key word) the flashing of images would be trivial. I did have to open mine up/use reset/disconnect the eMMC. Flip the switch (mine is a different switch which is interesting). I think those didn't really matter... it was just the boot was messed up (what Kali/Armbian/PostmarketOS fixed). I later found out about the LED lights being software lit, so it's hard to tell if the PBP is doing anything.
Do you know of a Manjaro image somewhere that works where I can flash it onto SD by balena etcher and then overwrite the eMMC content with it?
I would like to get Armbian to work (for apt/debian) ... but I read in another thread that the devs (or a dev) are not really trying to support it.
Yeah I don't really understand desktop environments enough is that suggesting that you would be able to change the package manager by doing that? I thought the issue with certain software not working with PostmarketOS/Alpine is this musl/libc thing.
I'll keep experimenting with it.
I really like the body of the laptop (sleek type) and the display is great. Physically only thing that could be better is the track pad. Regarding the laptop's body, the plastic is very flimsy without the bottom metal case which is mentioned in the wiki.
I'm going to see about battery life and what not, I used to obsess over that messing with cpu-freq utils.
RE: What OS have you recently flashed onto PBP eMMC? - by jcun4128 - 11-08-2022, 08:53 PM
  Happy eMMC and SDcard OS usage for Pinebook Pro Newbies... Paulie420 42 60,962 11-20-2023, 06:22 PM
  I'm booting from NVME but I want to switch back to eMMC acruhl 4 1,565 04-23-2023, 06:58 AM
Last Post: acruhl
  Doesn’t power on after flashing emmc badguru 3 1,307 02-25-2023, 09:00 PM
Last Post: badguru
  eMMC problem with Tow-Boot/u-boot on SPI repa 3 1,771 02-21-2023, 01:49 AM
Last Post: repa
  Partial boot after installing Manjaro on emmc regivanx 11 3,337 02-06-2023, 09:11 AM
  Unable to Boot anything (emmc or SDcard) line72 5 2,109 01-17-2023, 12:07 PM
Last Post: nfms
  Unable to boot from emmc after flashing it rfm83 3 1,849 11-08-2022, 10:59 PM
Last Post: rfm83
  Pinebook picky about which EMMC will boot flatulent_piney 8 3,217 11-05-2022, 06:03 PM
Last Post: ajtravis
  After Flashing eMMC, Will Not Boot Mossbot 5 2,457 09-28-2022, 06:22 PM
  U-Boot with direct NVMe boot support for eMMC/SPI Flash pcm720 125 217,365 09-27-2022, 07:41 AM
Last Post: olyavi
