can not boot pinebook pro from recent production run
It is true that you won't be able to boot from micro-SD if the SPI ROM doesn't transfer boot, which is what's happening to you.
I haven't had to do this, but I expect you could short the appropriate pins on the SPI ROM chip so that it doesn't boot and boot to micro-sd (or eMMC). Otherwise yes, you'll have to to the mask ROM mode thing.
The only reason I mention DietPi is that I know it works. I found out the hard way that all the bootable micro-sd cards I made did not actually boot with a blank eMMC. So I went to the wiki and tried various images, and DietPi was the first one that worked. I was able to use that to zero the eMMC and then write U-boot and NetBSD to it. So if I were you, I'd put that DietPi micro-SD in, and short the appropriate pins on the SPI ROM. When the boot process starts, you can remove your short. Once booted, immediately zero the SPI ROM.
:wq
[ SRA accepts you ]
RE: can not boot pinebook pro from recent production run - by KC9UDX - 10-22-2022, 04:14 AM
  Pinebook Pro Initial Impressions kunger 443 590,772 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,318 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 406 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 310 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 295 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 231 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 682 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 762 02-01-2024, 11:35 AM
Last Post: tomekdev
  uboot wont boot to SD card after upgrade jbradley419 7 882 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 302 01-16-2024, 09:17 AM
Last Post: jbradley419
