Are there any usable/ stable distros for PBP?
(10-22-2022, 02:55 AM)poVoq Wrote: You somehow messed up your Manjaro config. Sleep and hibernate was working last time I checked. Sounds more like it isn't hibernating at all and then discharges the battery completely.
As for "proprietary looking charge cable" you mean the barrel jack connector? That's about as non-proprietary and standard as it gets, you can literally buy them in any hardware store.
How could I mess it up on config on 2 installs? First was stock, 2nd was latest PBP version from Manjaro website booted from SD, what are the chances..... Oh I see barrel yeah, why didnt they just use USB C? (jus wondering if you know, curious)
Ironically the quote button isnt working here I see some kind of "void(0)Java" on the lower left part of the screen, and I just tried 2 different browsers, its like pine64 is always trying to make you a developer! So I will use reply function...
(10-22-2022, 03:57 AM)KC9UDX Wrote: Do be careful though; it seems that charging from both USB-C and the barrel jack at the same time can destroy the charging circuit.
Good advice, I think I tried this for a few seconds once, annoyed with slow charging time. USB C turbo charging would be nice like how the phones have. Wonder why include the barrel charger at all when can just use USB C. Could have added an extra USB port without it?
RE: Are there any usable/ stable distros for PBP? - by pineymousepad - 10-24-2022, 04:53 PM
  No Video Out on PBP on all major distros misha64 9 2,821 11-28-2023, 01:41 PM
Last Post: zaius
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,024 08-21-2023, 09:10 PM
Last Post: vanessadonald
  Manjaro PBP stable update 2022-06-19 bricked wpeckham 2 1,665 06-30-2022, 10:03 PM
Last Post: wangyukunshan
  Network stacks no longer works on PBP - all distros IT-That-uses-Linux 0 1,352 08-03-2021, 01:15 PM
Last Post: IT-That-uses-Linux
  [Panfrost] now support stable OpenGL ES 3.1 rimaille 0 2,054 06-10-2021, 11:23 PM
Last Post: rimaille
