DESIGN ISSUE? Speaker + vibration motor broke for the 2nd time
i was about to make a post about a similar issue but thought I might as well just comment here... I wasn't getting sound from the rear speaker, and the problem ended up being that the cable that runs under the battery somehow got half-unplugged from the main board.
A few days ago though it came unplugged for the nth time, so I stuck some foam above the plugs to hold it down better, but now the speaker isn't working *again*... I'll need to investigate that 4-line cable. I drop my phone pretty often, but never from high enough to do much damage (or so I thought).
Would *loosening* that strip make any difference? If it's ripping, then I'd think the sharp angle and tension when the phone is flexed would be the obvious culprit. Maybe loosening those boards from their glue or whatever is holding them down and shifting them together a bit could help prevent this, in addition to reinforcing it...
RE: DESIGN ISSUE? Speaker + vibration motor broke for the 2nd time - by 64_Tesseract - 12-14-2022, 04:32 AM
Thumbs Down Battery Issue or Power Management IC? bcoyle 2 1,562 03-20-2023, 12:54 AM
Last Post: bcoyle
  Odd Issue CzarD0mn 3 2,319 06-12-2022, 02:36 PM
Last Post: alaraajavamma
  Pinephone time goes too slow (not a 2115 year problem) grwlf 1 1,694 02-06-2022, 05:05 AM
Last Post: grwlf
Thumbs Up Airgapped Pinephone already reaches standby time of 6-8 days kuleszdl 6 4,291 01-19-2022, 01:27 PM
Last Post: GrapeJuice
  Pinephone convergence dock issue. Joshua 2 2,141 12-27-2021, 03:11 PM
Last Post: nelstomlinson
  New vibration motor not working Zebulon Walton 5 5,620 11-13-2021, 03:00 AM
Last Post: kqlnut
  Replacement Loud Speaker kmsgli 18 14,781 11-01-2021, 12:25 PM
Last Post: mickclark430
  pinephone circuit board design, conductive parts zetabeta 1 1,855 08-12-2021, 05:28 AM
Last Post: wibble
  Pine Phone Battery Issue vslash 21 19,089 08-09-2021, 07:35 AM
Last Post: mouffa
  Modem SMS issue(s) Helium75 3 3,884 08-03-2021, 06:30 PM
Last Post: bcnaz
