Airgapped Pinephone already reaches standby time of 6-8 days
Thumbs Up
I did a "quick" experiment to find out how long the Pinephone can stay on with all radios disabled (4G, wifi, bluetooth). It seems that this is at around 6-8 days now. I tested this on postmarketOS 21.12 on a braveheart device upgraded to the v1.2 mainboard. See also this issue:
https://gitlab.com/postmarketOS/pmaports/-/issues/1365
I think about retrying the same experiment but with the device being connected to the mobile network this time.
(01-06-2022, 05:50 PM)kuleszdl Wrote: Hi,
GREAT !
Thanks for sharing !
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
Sadly on Mobian it would be 0 days: https://gitlab.com/mobian1/issues/-/issues/399.
(01-13-2022, 07:31 AM)beta-user Wrote: Sadly on Mobian it would be 0 days: https://gitlab.com/mobian1/issues/-/issues/399.
A few months ago I was able to get a few days on standby with Mobian, only about an hour playing a video or similar though.
I tried playing webradio via firefox over wifi on pmOS, and this worked very well for several hours (without doing precise measurements, though).
With the screen on the battery Does go down quite fast, even just texting, I have on occasion talked for 2 full hours, but that leaves it almost dead.
The idle/sleep time seems to be improving, incoming calls with ample time to answer those calls is working well on my Pine phones.
if you forget and leave the screen on it will go dead quite quickly, so turn off your screen when not in use.!
Charging seems to have improved, with the battery at 16% and above it recharges very fast, when it falls into the lower percentages, it seems to start charging at a very low rate.
causing much longer charging times.
I am running a recent release of Mobian plus all the updates, ... ( I am still using the sd card)
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
Put the Pinephone in my bag today at 0600. Got to work and looked at it 1200, it was on 97%. Only the cellular radio was connected. BT was actually off and the Wifi was just not connected to a hotspot. I connected it to the work router and after 10 mins, battery level was down to 85%. It HAD downloaded two emails and a 100MB update.
It received two more emails by 1600 when I checked it, and was very warm.. Battery level was 22%... After disconnecting the wifi, and driving home with just the cellular connection (4G) i arrived at 1800 with 18%, so it appears the wifi consumes a great deal of power..
Is that the experience others are having?
Grape
  my pinephone melted norayr 6 785 04-04-2024, 07:22 PM
  Pinephone refusing to charge while suspended tiol 1 1,063 04-02-2024, 10:54 AM
Last Post: joH_N_Doe64
  various tricks to open the pinephone shengchieh 2 681 03-23-2024, 09:27 AM
Last Post: Ferriah
  pinephone can provide more than 500mA to a usb-c displayport device? unrznbl 2 317 03-21-2024, 08:52 AM
Last Post: unrznbl
  pinephone keyboard + dock question tuxcall 7 2,746 02-05-2024, 03:17 PM
Last Post: wigan
  Unsatisfactory GPS reception on PinePhone? LinAdmin2 53 55,455 12-17-2023, 11:42 AM
Last Post: robin.com.au
  PinePhone Pro not booting (Cap error!, pctl timeout) jealda 2 1,367 11-16-2023, 05:03 AM
Last Post: DrYak
  Pinephone frame damages Uturn 2 952 10-23-2023, 02:49 AM
Last Post: Uturn
  PinePhone Keyboard KJ6OHG 11 8,026 08-23-2023, 03:25 AM
Last Post: Kali
  PinePhone constantly vibrating and won't take charge ImmyChan 5 5,417 07-23-2023, 03:49 PM
Last Post: kb-zealot
