Pinephone time goes too slow (not a 2115 year problem)
Please help me to figure out what is going on with the system time of my Pinephone. I noticed that both system and hardware clocks run too slow for some unknown reason. For example, I could see that NTPD adjusts the clock every several hours.
I wrote a script collecting 3 kind of times: the network time (from time.nist.gov), the system time and the rtc (hwclock) time. Then I did:
1) Stop ntpd
2) Run this script  for about a day on my desktop PC and on a Pinephone (Pinephone was in a suspend most of the time)
3) Collect the data and plot the results this renderer
The results are:
[Image: clockskew.png?raw=true]
Vertical axis is the time difference, in seconds
Horizontal axis is the running time of my script, in minutes
The blue and orange lines show the difference between remote (time.nist.gov) and local clocks: system and hwclock.
As we may see, the clock skew tend to increase quickly on a pinephone.
The question is - why, and how to fix.
Note, that it is unlikely a known "year 2115" problem, because I can see both errata and the correction patch applied to the kernel.
Note2, I did stop NTPD, so I can't explain right now why the pinephone time difference became zero at 450th minute of the measurement. Maybe there is other agent which does the correction, besides ntpd.
I use Megi's kernel 5.13.7, Crust fw is 0.4, the os is MobileNixos.
I believe it is a hardware/firmware problem. Let me know if there is a better place to post it.
The story continues here: https://github.com/crust-firmware/crust/issues/203
  Pinephone - broken power button rorus 14 22,726 05-17-2026, 03:52 PM
Last Post: EuvzO8
  Pinephone + Keyboard for sale, little use ruemoo 15 10,415 03-05-2026, 10:14 AM
Last Post: diazman39
  PinePhone 16 GB – Free to a Good Home Anna 2 1,251 01-20-2026, 01:43 PM
Last Post: Anna
Bug PinePhone modem keeps "disappearing" Kevin Kofler 17 18,829 12-12-2025, 03:27 AM
Sad PinePhone USB-C port and audio jack failure Kevin Kofler 4 7,421 12-11-2025, 08:57 AM
Last Post: jakfish
  Recycling pinephone as home server mdk 6 2,508 12-01-2025, 02:57 AM
Last Post: mdk
  PinePhone, PinePhone Pro, Keyboard/Accessories for sale brb78 5 1,893 11-30-2025, 05:45 AM
  Modem Issues with the Pinephone Temmie19 5 5,304 07-02-2025, 12:50 PM
Question Third-party cheap touchscreen/LCD for the Pinephone - lost knowledge? mikeb 2 3,755 06-21-2025, 05:19 PM
Last Post: mikeb
  Pinephone not booting sd card... bruv 1 2,745 03-25-2025, 08:51 PM
