Connection to WiFi with OWE
Just to add,
`nmcli con modify WIFI_OWE 802-11-wireless-security.key-mgmt owe`
did not helped.
What is the correct way to verify I'm using latest WiFi driver? Or any way to use some alternative driver?
Connection to WiFi with OWE - by IhorOlkhovskyi - 08-31-2022, 07:36 AM
RE: Connection to WiFi with OWE - by IhorOlkhovskyi - 09-01-2022, 08:48 AM
  Kernel Not Detecting Wifi tallfrye 10 1,055 01-01-2024, 06:57 AM
  Is there a way to turn off Wifi completely? jirow 10 7,974 06-20-2022, 05:53 AM
Last Post: Kaythe
  RTL8811AU usb wifi for pbpro vlut 0 1,324 12-02-2021, 05:23 AM
Last Post: vlut
  Mini-Howto: ROCK64 USB 3.0 WIFI Adapter (Rabbit-ear) on Manjaro Dendrocalamus64 1 2,417 11-14-2021, 03:41 PM
Last Post: Dendrocalamus64
  Wifi disconnecting after few minutes hellojack 0 1,404 09-16-2021, 02:50 AM
Last Post: hellojack
  Fix your Pinebook Pro speaker connection KC9UDX 12 11,232 07-08-2021, 02:10 AM
  Advice on increasing WIFI range stozi 2 4,099 03-29-2021, 06:57 AM
Last Post: barray
  Curious about problem with PBP Wifi kendew 3 4,766 01-14-2021, 11:16 AM
Last Post: clover
  Privacy switches - cutting power to wifi card as400 1 2,812 08-10-2020, 09:48 AM
Last Post: belfastraven
  Soldering internal Wifi/Bluetooth antenna petet0n76 1 3,655 06-20-2020, 12:01 PM
