Privacy switches - cutting power to wifi card
According to this ---> https://wiki.pine64.org/index.php?title=...y_Switches, if I press pine logo key plus F11 for three seconds I can cut the power off to the wifi card.
I tried this but actually I am not able to say cutting power really works judging by the power consumption statistics. It stays on the same level.
Can anyone confirm/deny that cutting power really works ?
(08-10-2020, 12:13 AM)as400 Wrote: According to this ---> https://wiki.pine64.org/index.php?title=...y_Switches, if I press pine logo key plus F11 for three seconds I can cut the power off to the wifi card.
As I'm sure you've seen, wifi doesn't work when  disabled with F11.  I am curious though how you are comparing energy usage.  I would imagine that if wifi is turned off via  software,  the energy usage  vs  using F11 to turn off would not be different.  I would have expected to see  some difference with F11 disabling and using wifi,,  but it might take hours to see, especially if the screen is on and the storage device(s)  is using  a lot of power.    Perhaps @tllim  could add some insight here.
  Pinebook Pro on Debian 12 Power Issue u974615 1 304 03-13-2024, 10:46 AM
Last Post: u974615
  Kernel Not Detecting Wifi tallfrye 10 927 01-01-2024, 06:57 AM
  Increasing the maximum power draw dsimic 15 19,394 11-21-2022, 03:36 AM
Last Post: bircoph
  Alternative Power supply options gallomimia 13 17,832 11-13-2022, 06:10 PM
Last Post: pineymousepad
  PBP booting but stops at flashing power led jonasd 13 5,389 09-26-2022, 12:17 AM
Last Post: jonasd
  Connection to WiFi with OWE IhorOlkhovskyi 1 1,365 09-01-2022, 08:48 AM
Last Post: IhorOlkhovskyi
  Is there a way to turn off Wifi completely? jirow 10 7,809 06-20-2022, 05:53 AM
Last Post: Kaythe
  RTL8811AU usb wifi for pbpro vlut 0 1,306 12-02-2021, 05:23 AM
Last Post: vlut
  Blinking red light for charger, no power-on bifo 11 13,681 11-30-2021, 01:37 PM
  power on PBP if your keyboard is dead? stozi 0 1,318 11-29-2021, 01:55 PM
Last Post: stozi
