Wifi disconnecting after few minutes
Hello, my pinebook pro's wifi is disconnecting after few minutes.
I tested on Arch ARM(Uses manjaro kernel), and Manjaro ARM(latest kernel).
It does connect to wifis, but it disconnect on itself after few minutes.
I tried changing router's wifi channel, didn't help. I also tried with different router.
I think updating the kernel to 5.14 broke it.
Does anyone else have same problem?
  Kernel Not Detecting Wifi tallfrye 10 776 01-01-2024, 06:57 AM
  Connection to WiFi with OWE IhorOlkhovskyi 1 1,310 09-01-2022, 08:48 AM
Last Post: IhorOlkhovskyi
  Is there a way to turn off Wifi completely? jirow 10 7,538 06-20-2022, 05:53 AM
Last Post: Kaythe
  RTL8811AU usb wifi for pbpro vlut 0 1,269 12-02-2021, 05:23 AM
Last Post: vlut
  Mini-Howto: ROCK64 USB 3.0 WIFI Adapter (Rabbit-ear) on Manjaro Dendrocalamus64 1 2,316 11-14-2021, 03:41 PM
Last Post: Dendrocalamus64
  Advice on increasing WIFI range stozi 2 3,990 03-29-2021, 06:57 AM
Last Post: barray
  Curious about problem with PBP Wifi kendew 3 4,615 01-14-2021, 11:16 AM
Last Post: clover
  Privacy switches - cutting power to wifi card as400 1 2,727 08-10-2020, 09:48 AM
Last Post: belfastraven
  Soldering internal Wifi/Bluetooth antenna petet0n76 1 3,563 06-20-2020, 12:01 PM
  WiFi 6 for the Pinebook Pro tsys 17 29,737 06-14-2020, 06:09 AM
Last Post: manawyrm
