Pinetime Screen issue after bootloop troubles
(09-15-2022, 05:40 AM)wibble Wrote: The heart rate sensor window is clear plastic, stuck to the back cover. Depending on how well I align it when I put the back cover on it sometimes looks like there's some pressure on the back, raising the middle of the window slightly. It's seem most easily if you view at an angle to see the distortion of the reflection on the window. I could imagine this leading to a leak over time. Since I stuck the back on myself I've assumed it will leak, but between sweat and rain it's been ok so far.
I believe @Spater had a sealed unit, so this may indicate some manufacturing check that needs to be performed during assembly.
The erosion definitely looks as if it came through the area where there is the heart rate window. The rest of the PCB looks corrosion free.
It still may not explain the display though.
@Spater How did you clean the green corrosion? Ideally you try some non-conductive anti-corrosion cleaner (maybe pure alcohol?).
RE: Pinetime Screen issue after bootloop troubles - by barray - 09-15-2022, 06:37 AM
  PineTime at FOSDEM jmlich 5 928 02-07-2024, 11:48 PM
  PineTime turns off when removed from cradle tynstar 0 294 01-31-2024, 11:57 AM
Last Post: tynstar
  Bluetooth Connection Issue Orionbelt 2 2,198 11-24-2023, 05:27 PM
Last Post: BrianPineFan
  PineTime and Amazfish on Ubuntu Touch jmlich 1 811 10-14-2023, 04:12 PM
  PineTime is dead!! Markdanni123 12 14,155 09-18-2023, 10:17 PM
Last Post: ccchan234
  PineTime Sleep Tracking any_mouse 12 12,706 07-10-2023, 05:41 PM
Last Post: davidair
  PineTime Dead out of box? henkery 1 1,288 03-12-2023, 04:34 PM
Last Post: henkery
  Pinetime almost dead... only shows Infinitime logo. lightweight 8 7,034 02-11-2023, 09:30 AM
Last Post: alexmitroff
  Screen stopped working properly pcfreak9000 3 1,737 01-18-2023, 04:28 PM
  PineTime beginner MV1791 2 2,272 01-09-2023, 11:52 PM
Last Post: Canyonless
