Pinetime Screen issue after bootloop troubles
There are some pics of the internals here:
https://lupyuen.github.io/articles/build...controller
The battery has some double sided tape that sticks it to the board (at least on my developer one) so be careful when you lift it. I haven't tried reseating the connectors so can't give you any hints on those. The connector is the only potential hardware issue I can think of that's reasonably easy to try fixing. You might be lucky. Cracked traces and failing solder joints are at another level entirely.
I stuck the back on mine with some B-6000 glue after some silicone proved insufficiently strong. I may have a bit of silicone residue on the metal side as it came unstuck in the recent hot weather.
RE: Pinetime Screen issue after bootloop troubles - by wibble - 08-31-2022, 11:34 AM
  PineTime at FOSDEM jmlich 5 1,003 02-07-2024, 11:48 PM
  PineTime turns off when removed from cradle tynstar 0 317 01-31-2024, 11:57 AM
Last Post: tynstar
  Bluetooth Connection Issue Orionbelt 2 2,242 11-24-2023, 05:27 PM
Last Post: BrianPineFan
  PineTime and Amazfish on Ubuntu Touch jmlich 1 844 10-14-2023, 04:12 PM
  PineTime is dead!! Markdanni123 12 14,298 09-18-2023, 10:17 PM
Last Post: ccchan234
  PineTime Sleep Tracking any_mouse 12 12,821 07-10-2023, 05:41 PM
Last Post: davidair
  PineTime Dead out of box? henkery 1 1,315 03-12-2023, 04:34 PM
Last Post: henkery
  Pinetime almost dead... only shows Infinitime logo. lightweight 8 7,132 02-11-2023, 09:30 AM
Last Post: alexmitroff
  Screen stopped working properly pcfreak9000 3 1,788 01-18-2023, 04:28 PM
  PineTime beginner MV1791 2 2,298 01-09-2023, 11:52 PM
Last Post: Canyonless
