Stuck in bootloader
(06-05-2022, 09:26 AM)MLG_Herobrine Wrote: Note: If I hold the power button, it shows the green, blue, and red cycles. I looked at the wiki, and don't understand exactly how to use these.
according to this info:
Quote:At startup, the bootloader displays a logo and its version:
Then, it waits for ~5s in case the user presses the button. The progress is shown by the color of the logo.
When the user just wants to run the current firmware, they won't touch the button, and the logo will be filled in green.
When the timeout is elapsed, MCUBoot will be run. It'll swap the firmware if needed and then run the firmware from the primary slot.
If the user presses the button until the logo is drawn in blue, the previous version of the firmware will be reverted.
If the user presses the button longer, until the logo is drawn in red, the recovery firmware will be loaded into the primary slot and will be run after the next reset.
also, maybe links or some steps from this post could be useful (try to install recovery firmware)
Away
Stuck in bootloader - by MLG_Herobrine - 06-05-2022, 09:26 AM
RE: Stuck in bootloader - by ITCactus - 06-06-2022, 06:14 AM
RE: Stuck in bootloader - by MLG_Herobrine - 06-06-2022, 04:04 PM
  Another stuck watch! Ralpharama 11 3,198 06-07-2023, 09:10 AM
Last Post: Ralpharama
  Stuck in OTA update mode mark1250 4 4,262 06-01-2023, 10:06 AM
Last Post: feketej
Exclamation Stuck at Infinitime Logo with 18% battery on full charge? PiningFjord 1 1,230 03-13-2023, 05:05 PM
Last Post: PiningFjord
Question Green skin-facing LED stuck on aereaux 0 840 03-05-2023, 02:02 PM
Last Post: aereaux
  Pinetime stuck at infinitime logo monto 3 3,006 08-27-2022, 11:26 AM
Last Post: monto
