JumpDrive isn't working
I have a Beta edition PinePhone which had the default Manjaro OS installed, but things started breaking after I pacman -Sy && pacman -Su-ed it. The first warning sign was the on-screen keyboard not showing up on the SDDM lock screen, and after a reboot, SDDM outright failed to start. sshd was still working, so I installed and started LXDM (after stopping and disabling SDDM), and although it started succesfully, the on-screen keyboard still failed to show up.
Next, I tried replacing the contents of /etc, /usr, /var, and /opt on the eMMC with a fresh copy from Manjaro's PinePhone image by copying them over without flashing the entire drive (which was a horrible idea in retrospect and wouldn't have saved any time vs. reflashing from microSD), but something went horribly wrong because sshd went down almost immediately, and I can't tell if the phone is on any more.
Just now, I dd-ed JumpDrive onto a microSD card and booted my phone, but the only difference seems to be that a green LED in the upper left corner of the front of the phone turns on; the screen itself is off, and I don't see any new block devices from my PC. I think my immediate questions boil down to these:
  1. Is my host PC missing a driver? dmesg doesn't seem to have picked up any plugging/unplugging events while the phone is on and ostensibly booted into JumpDrive. lsusb likewise doesn't change with the phone connected or disconnected. If the kernel driver needed to detect a PinePhone running JumpDrive isn't installed/loaded by default on a typical Arch system, this could be a quick and easy fix.
  2. Is it normal for JumpDrive to start with a blank screen? If not, how should I troubleshoot it? I've already downloaded the image twice with cache cleared, and the checksums match.
  3. If all else fails, is there a way to have the eMMC reflashed more "manually?" I don't have much in the way of appropriate tools/equipment, though...
Thanks!
JumpDrive isn't working - by phytocube - 06-05-2022, 12:21 AM
RE: JumpDrive isn't working - by zetabeta - 06-05-2022, 03:51 AM
RE: JumpDrive isn't working - by phytocube - 06-05-2022, 03:22 PM
  4G VoLTE calls confirmed working with carrier x dcinoz 15 11,973 03-09-2024, 11:38 PM
Last Post: dcinoz
  Jumpdrive broken? eMMc broken Uturn 5 1,779 04-21-2023, 12:37 AM
Last Post: Uturn
  MMS sending stopped working amindfv 2 1,257 01-16-2023, 09:44 PM
Last Post: treebeard
  Instructions to get pinephone working on USA carrier omarcomputing 1 1,379 10-08-2022, 04:45 PM
  Jumpdrive not booting Kimberley van Buyten 1 1,049 05-28-2022, 01:00 AM
Last Post: Kimberley van Buyten
  SIM card slot not working dekrets 2 2,218 02-12-2022, 11:09 AM
Last Post: dekrets
  Can't get autofocus working duncan_bayne 4 2,950 01-22-2022, 09:17 PM
Last Post: duncan_bayne
  PinePhone Beta 3GB modem not working hannescam 15 9,148 01-19-2022, 02:08 AM
Last Post: bcnaz
  Video Out not working BenniTec 7 5,200 10-21-2021, 11:56 AM
Last Post: BenniTec
  How did you get data working on PureTalk? nelstomlinson 2 2,906 09-26-2021, 03:50 PM
Last Post: nelstomlinson
