Stable Beta Factory Release
Disclaimer: I don't own a PinePhone Pro, (but I do own a Pinebook Pro with the same SoC / CPU).
Are you sure your "USB-C hub with DP out" device uses DisplayPort protocol on the phone side?
The original USB-C alternate mode for video was DisplayPort. However, the HDMI people wanted the same treatment, so they created a different USB-C alternate mode for HDMI, which is totally in-compatible with "USB-C alternate mode for DisplayPort:".
A USB-C alternate mode for video device can have any monitor connector on it, like HDMI, DisplayPort or VGA. A simple, (or complex), converter is needed. However, the SoC / CPU used in the PinePhone Pro, (and Pinebook Pro), requires USB-C alternate mode DISPLAYPORT. Without that, it won't work. (Of course, software support is also required....)
https://gas-stationsnearme.com/
Vendors have been a bit vague on what there device specifications are, at times. Some outright leave off what the host side protocol is, USB-C alt. mode DisplayPort, or USB-C alt. mode HDMI.
Good luck. Maybe someone else has better information.
Stable Beta Factory Release - by Emilio - 03-23-2022, 02:37 AM
RE: Stable Beta Factory Release - by MichaelGriffin - 05-15-2022, 08:38 PM
  Is Manjaro Plasma stable for anyone? projectcato 120 54,098 04-18-2023, 08:26 PM
Last Post: mburns
  Factory AOSP image but for your SD card! Danct12 14 8,509 04-03-2023, 06:21 PM
Last Post: strungar
  PinePhone Pro Manjaro Plasma Mobile Beta 13 & No Audio with Phone Calls X0X0X0X0X0 0 1,114 11-02-2022, 02:09 PM
Last Post: X0X0X0X0X0
  Megapixels - Camera App - Works w. Beta NOT Pro iwm 3 2,980 11-01-2022, 02:13 PM
Last Post: mburns
  Manjaro Plasma Beta 11 sleep issue after 3/22 update Fred Zyphal 6 3,989 05-22-2022, 12:37 PM
Last Post: magdesign
  Manjaro-phosh beta 22 release won't boot after update tckosvic 1 1,541 02-28-2022, 09:46 AM
Last Post: tckosvic
  Factory AOSP image source? krazey 0 882 02-01-2022, 03:53 PM
Last Post: krazey
  Siglo interfaces w. Beta not Pro. iwm 0 835 01-05-2022, 02:01 PM
Last Post: iwm
