03-26-2022, 09:12 AM
(03-22-2022, 06:59 PM)pentamassiv Wrote: Hi,
I put Tow-boot on the SPI. Then I flashed Manjaro-ARM-gnome-pbpro-22.02.img to a SD card, booted from it and used the manjaro-arm-installer to put Manjaro on my eMMC. I selected the minimal version with FDE. The installer finishes and I turned of the PBP. I removed the SD card and turned it on again. Tow-boot showed up and I pressed ESC to select to boot from eMMC (I guess this is not required since the eMMC is higher up in the boot order than the SD). Booting however fails each time and gives the errors that are visible in the following image: https://imgur.com/Wek8KNw
Did this happen to anyone else? I tried multiple times now with tow-boot and u-boot. I tried with the minimal and gnome versions with and without FDE. Can somebody help please?
I currently have the exact same problem, except that I am trying to use the default U-Boot that comes with Manjaro and have nothing on my SPI. I have tried both directly flashing the EMMC and flashing the EMMC from the manjaro-arm-installer (KDE version both times). I have even tried completely zeroing out the EMMC before writing the image, but I still get errors similar to the ones in your photo. Finally, I gave up, and just use Manjaro from a MicroSD card.
