Mobile case wanted - with wireless charging!
(03-10-2022, 08:25 AM)thorensjubilee Wrote: Hello,
Yes, but I want a soft, protective case, and Pine phone don't make them, otherwise I'd buy them!
Chris
If you use a case from a Galaxy Xcover Pro the dimensions are very close and the buttons are close as well. If its a Folio style case that holds just the corners it will work you will just have to cut a spot for the camera.
Here is a hard case I bought for a xcover pro and drilled holes for the camera
https://forum.pine64.org/showthread.php?tid=16171
I am in the process of ordering an otter-box case for the xcover pro to see if i can modify it to fit since it looks like a more sturdy case.
RE: Mobile case wanted - with wireless charging! - by kmsgli - 03-11-2022, 06:40 AM
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 317 04-02-2024, 11:50 AM
  can I retrieve accidentally deleted voice mail with T mobile ? HLing 4 986 12-13-2023, 01:24 AM
Last Post: oldschool
  New Zealand network providers mobile data Linux2thabone 3 3,354 08-05-2023, 06:17 AM
Last Post: SchizoPinePhone225
  US Mobile, via T-Mobile, won't support Pinephone Pro - SOLVED, SIMPLY jovval 10 3,506 07-07-2023, 12:06 PM
Last Post: jovval
  Problems updating KDE Plasma Mobile OS IMSAI8080 6 3,484 06-30-2023, 11:39 PM
Last Post: ionmich
  Current Situation With Setup and Carrier Activation With Tracfone Verizon T-Mobile pinephoneuser22 0 739 05-26-2023, 08:40 PM
Last Post: pinephoneuser22
  Cannot call at several mobile phones Gon 3 1,404 05-04-2023, 05:18 AM
Last Post: Gon
  WIRELESS CHARGING ADD-ON CASE Fred Zyphal 4 2,644 08-28-2022, 05:17 PM
Last Post: Fred Zyphal
  Charging the phone while it is off orbital 1 1,253 07-05-2022, 12:19 AM
Lightbulb pinephone mobile dock jasmin763 2 1,767 06-06-2022, 09:06 AM
Last Post: 98cwitr
