Unable to Boot
(01-31-2022, 11:46 AM)Barugon Wrote: There are apparently two contacts on the motherboard (I believe they're labeled DIS eMMC) that you have to short in order to bypass eMMC and boot from the SD card.
So I had some people on the Pinephone chat try to help me out a bit with this. There is a RE button on the explorer edition that can do it instead. I was getting into mask ROM mode which I was informed means that it's unable to boot from the SD card I have inserted as well. I tried multiple SD cards, both of which worked before this happened and used them both for OS images, so they worked in my PPP. The result didn't change with different SD cards, and I'm still stuck unable to boot from either internal or inserted SD.
Unable to Boot - by codefossa - 01-29-2022, 09:36 AM
RE: Unable to Boot - by Barugon - 01-31-2022, 11:46 AM
RE: Unable to Boot - by codefossa - 01-31-2022, 01:19 PM
RE: Unable to Boot - by Ulfnic - 01-31-2022, 07:44 PM
RE: Unable to Boot - by codefossa - 01-31-2022, 01:21 PM
RE: Unable to Boot - by Conjada - 01-31-2022, 01:42 PM
RE: Unable to Boot - by codefossa - 02-01-2022, 06:08 AM
  Can't boot Pinephone Pro into Factory Test Build for Hardware Checking jydoxcen 3 837 02-17-2024, 04:04 AM
Last Post: fxc
  Mobian + tow boot + emmc flash = boot loop spropine 4 3,291 12-31-2022, 09:14 AM
Last Post: mburns
  Need to re-write U-boot from Pinephone pro currently in mass rom mode wolverine1 6 2,984 11-20-2022, 05:58 AM
Last Post: wibble
  Tow-Boot issue Barugon 1 1,386 10-22-2022, 03:22 AM
Last Post: AndrewBlackmiller
  pinephone pro boot: kernel image not aligned on 64k boundary kmerfeld 2 2,088 08-15-2022, 10:35 AM
Last Post: ajaso
  pinephone pro don’t boot anymore :/ (I erased bootloader by mistake) elode 9 5,010 06-20-2022, 11:16 AM
Last Post: elode
Information Fix PinePhone Pro when unable to boot due to drained battery butjar 7 6,082 05-21-2022, 01:24 PM
Last Post: 98cwitr
  My new Pinephone Pro does not boot any more jlioret 3 2,621 05-21-2022, 12:08 PM
Last Post: 98cwitr
  Tow-Boot on PP vasir 1 1,317 04-28-2022, 05:22 PM
Last Post: vasir
  Boot order Barugon 13 8,162 03-11-2022, 09:16 AM
Last Post: kaida
