Can't boot Pinephone Pro into Factory Test Build for Hardware Checking
I can't boot my newly received Pinephone Pro into the Factory Test Build for Hardware Checking linked to by the phone's wiki page. I've verified the md5 hash of the downloaded image, and tried two SD cards. The accompanying instructions on that wiki page seem to be out of date, referring to an "RE button" that is only on phones sold between January and July 2022, according to other sections of the same page. Here's the procedure I've pieced together for my phone and attempted:
  1. Download file and verify md5 hash.
  2. Gunzip it.
  3. sudo dd if=pinephone_pro_dd_android9_QC_Test_SDboot_20220215-8GB.img of=/dev/sdb bs=1M status=progress conv=fsync
  4. Put the SD card in the phone.
  5. Power on / buzz once.
  6. Hold volume down, wait for another buzz, and release.
  7. LED changes to blue.
  8. At this point it should boot from the SD card, but it buzzes and flashes red and yellow, and boots into the stock Manjaro with Plasma Mobile.
Is that image supposed to work with phones sold after July 2022?
And if so, are my above steps correct?
I'm able to boot into a postmarketOS image, so the trouble here is Pine64's Factory Test Build image. Is there a newer version of it?
I booted into it just fine. I received my pppro december 2023. You have to hold down that RE button pushed in while powering (insert charging cable or power-on button). You flash it to SD card, not eMMC btw
Tow-Boot on the SPI is probably not compatible with the factory test, which is why it worked with the RE button disabling the SPI.
Edit: I just checked and the manual says to hold the RE button.
Question Pinephone Pro for a Debian user? primesocial 2 202 04-15-2024, 03:01 AM
Last Post: zetabeta
  PinePhone Pro silver lining, it’s fast, real damn fast ashoka232 0 510 03-20-2024, 01:45 AM
Last Post: ashoka232
  PinePhone Pro Black Screen CrimsenRaven 2 393 03-16-2024, 11:40 AM
Last Post: tmoj
  PinePhone Pro Review tmoj 2 696 03-14-2024, 07:14 AM
Last Post: tmoj
Question Phone call with the pinephone pro dfs 5 4,287 02-10-2024, 09:54 PM
  Average Joe review of Pinephone Pro (March 2023) alaraajavamma 6 10,353 01-06-2024, 11:32 AM
Last Post: mikehenson
Question T-Mobile and Pinephone Pro in the US jydoxcen 4 856 01-02-2024, 09:08 AM
  Pinephone Pro Screen Protector jydoxcen 11 1,452 12-21-2023, 07:58 AM
Last Post: zetabeta
  Pinephone Pro does not start with RE button pressed c0ssan 10 5,415 09-28-2023, 09:21 AM
Last Post: R0bbi3Mack
  Is my pinephone pro worth resurrecting? tckosvic 5 3,039 09-14-2023, 06:48 AM
Last Post: DaForest
